A little bit of extra hydrolock prevention without a snorkel.
Taco04
While this mod is not new on Yotas I have yet to see it done on a 5th gen. I have never liked the factory air intake pick up point on these Runners since it sits almost on top of the fender liner and a bit forward. After pulling out the Air box today while working on a few other things I took a quick look and decided this could be a simple fix. I had a section of 4” automotive air duct and found that after pulling the foam gasket material it fit perfectly over the air box intake tube and could be clamped down with a hose clamp. Below are some pics of the perp.
Factory air pick up point notice how close it sits to factory fender liner also notice how high the fender is back above it.
Hose attached to air box intake tube with splash guard.
Below pic of splash guard removed since it's no longer needed.
Next I pulled the hose through the intake hole and attached it back to the air box. After wrestling with the fender liner I got it loose and found a few points where I could zip tie the air duct tightly to the inner fender so that there was no movement of the air duct. All in all I gained about 4-6” of clearance over the stock set up the pics don't show the end of the intake but it is 3/4 of the way down and about 1-2" from the top of the fender.
4" air duct still fits through the factory cut out.
This pic doesn't do justice since it doesn't show the end of the hose and the camera pic is up at an angle. The hose is about an 1-2" from the top of the fender now.
This is a quick and easy mod for those who don’t want a snorkel but would like a bit of extra insurance. While having the liner off I also noticed that there is a hole behind the fire wall into the cowl for the cabin filter & wiper motors etc. It looked big enough to run the hose through so it could be run even higher yet I have heard this can wreak havoc with the AC since the motor and an AC will be sharing pick up points. Yet this can also be remedied by having the AC on Recirculation as well. Any way thought I would share this cheap and easy mod.
So what are you running for a filter now?
Also the design isn't that bad with the splash guard as it should be facing with the back toward the front of the vehicle.
Either way, not a bad mod I suppose.
It goes straight back to the factory air box. Since I have a different bumper I had to trim the fender liners. I trimmed a bit more than I should plus the way the liner is molded it leaves a bit of a gap so this was an easy fix. Also after running through a couple of nasty mud holes I have seen dried mud in my air box so I figured better safe than sorry. The air intake pick up point is now higher or about even than the door handles. If I do ever get in water this deep with my luck the secondary air injection will short circuit and kick on and hydrolock the motor lol....
Below is a pick of the hose clamp connecting back to the air box.
would love an update bump
Wow blast from the past! I am still running this setup with Zero issues it does add a tad bit to the intake temps but not enough to affect anything. Also still tons of 2nd gen Taco guys running this setup as well. I plan on running this same setup on my Taco after we finish the engine cage I just like the clean look of no snorkel...
seltzernator
