Old 03-13-2016, 06:18 PM #1
Dark Lord's Avatar
Dark Lord Dark Lord is offline
Real Name: Chris
Dark Lord is on a distinguished road
Dark Lord's Avatar
Real Name: Chris
Icon Rear Remote Reservoir Help (56505R)
Does anybody have a photo of how the remote reservoir is secured to the frame? I installed my lift last weekend, and have since just zip tied my rear remote reservoirs temporarily for two reasons. First off, one of my shocks didn't come with the hardware kit. Second, the instructions aren't entirely clear on how to mount the remote reservoir (in my opinion). Any help would be greatly appreciated.
2015 Limited 4x4 -- Icon Stage 2 -- Rokmen UCA -- SCS F-5 wheels in gunmetal gray -- Nitto Ridge Grappler 285/70R17
Instagram @roadwingit
Dark Lord's Cross Country Trip Report 2013
Dark Lord's Cross Country Trip Report 2016
Dark Lord is offline   Reply With QuoteReply With Quote
Old 03-13-2016, 06:29 PM #2
jmf_tracy jmf_tracy is offline
jmf_tracy is on a distinguished road
sorry, no pics
but, this is easy.
take the mud flaps off.
mock up where you want them mounted on the frame, you want them as far back as possible.
you need to drill a 21/64" (.328) hole then use the self tapping screw to form the thread. use the hose clamps to secure them to the bracket.
i had to cut the mud flap just a little bit on the driver's side for my installation.
jmf_tracy is offline   Reply With QuoteReply With Quote
Old 03-13-2016, 06:30 PM #3
Dark Lord's Avatar
Real Name: Chris
Dark Lord's Avatar
Real Name: Chris
Ah gotcha, thanks
Old 03-13-2016, 06:32 PM #4
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
Ah gotcha, thanks
Gimme a sec and I'll go grab a photo of mine.
I don't own a 4Runner anymore.
LawnDart is offline   Reply With QuoteReply With Quote
Old 03-13-2016, 06:43 PM #5
LawnDart's Avatar
LawnDart's Avatar
Old 03-13-2016, 07:00 PM #6
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
you shouldn't have to drill anything, there's a threaded hole (or 2) back there already. when i did mine i discovered ICON mistakenly included SAE, not metric, hardware for the reservoir mounts, so i had to scrounge up a couple bolts in the right size.
definitely remove the rear mudflaps to make the job much easier. LawnDart's look right on.
enjoy the ride with the new shocks!
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
Old 03-13-2016, 07:02 PM #7
Dark Lord's Avatar
Real Name: Chris
Dark Lord's Avatar
Real Name: Chris
Originally Posted by LawnDart View Post
I appreciate the help guys. Quick question, did either of you adjust your Icon coilovers at all or leave them on the stock setting? I have the overland rear springs, and don't mind the rake, but it's almost too much.
Old 03-13-2016, 07:11 PM #8
LawnDart's Avatar
LawnDart's Avatar
I'm running OME 898 springs in the rear, because I'm carrying recovery gear, CBI rear bumper, swing arm, spare tire, jerry cans. And because of the front with my winch, pelfrey bumper, and group 31m battery, the front sagged a bit, so we have the coilovers adjusted to keep the vehicle nice and level with a full fuel tank/standard load (recovery gear and tools).
It has stiffened up the front suspension, but I don't find it to be stiff off road, and on road it helps tame the handling characteristics of it being an SUV/Truck.
Old 03-13-2016, 07:14 PM #9
Dark Lord's Avatar
Real Name: Chris
Dark Lord's Avatar
Real Name: Chris
Did you end up maxxing it out or do you still have some more room to adjust? I bought the overland springs because I plan on loading down the rear with gear for trips, and since I bought the new SSS rear bumper.
Old 03-13-2016, 07:17 PM #10
LawnDart's Avatar
LawnDart's Avatar
I assume you mean the adjustments in the front, because there's none in the rear.
Frankly you're going to need to install the bumper and adjust after a few days because the rear end will settle.
Mine aren't maxed out, I can get a measurement on the amount of exposed thread, but I know we could go a little further but frankly IF anything I feel I could maybe dial back the front lift a ton just so there's less rear rake when under a full expedition load.
Old 03-13-2016, 07:20 PM #11
Dark Lord's Avatar
Real Name: Chris
Dark Lord's Avatar
Real Name: Chris
Yeah, I'm referring to the front. I didn't know the rear springs would settle eventually. The rake didn't look bad at first, but upon closer inspection, it looks pretty drastic with the fronts at stock height. I might mess with it tomorrow when I get it on the lift to install the hardware for my rear shock.
Old 03-13-2016, 07:23 PM #12
i have the ICON "2-inch" rear springs (yielded a bit more than 2 inches in the back) and with the front coilovers at their stock setting it pretty much preserved the factory 2" rake.
i drove it for a while that way, then adjusted the coilovers up about a half inch. things definitely settle; give them time.
Old 03-13-2016, 07:25 PM #13
Dark Lord's Avatar
Real Name: Chris
Dark Lord's Avatar
Real Name: Chris
This helps a lot. I definitely need to adjust mine then since the overland springs add 3" in lift.
Old 03-13-2016, 07:29 PM #14
LawnDart's Avatar
LawnDart's Avatar
Old 03-13-2016, 07:50 PM #15
yeah, both front and rear will "relax" a bit with some time, and the process will be accelerated if you give it some good opportunities to stretch its legs and flex.
congrats on the new suspension. you'll love it.
FS 3rd Gen Icon 2.5 Rear Remote Reservoir Shock $400 NC jij0226 For Sale: Suspension/Wheels/Tires 4 03-02-2016 06:20 PM
FS: rear icon 2.5 remote resi shocks $500 GX4SEVEND For Sale: Suspension/Wheels/Tires 8 01-25-2016 12:02 PM
Used rear Icon 2.5 remote resi price? GX4SEVEND 4th Gen T4Rs 5 01-15-2016 06:41 PM
Icon Rear Piggyback Reservoir 2.5 V-series shocks Andres_Huerta For Sale: Suspension/Wheels/Tires 18 10-14-2015 02:44 PM
2.5 Icon remote resivor with cdc clicker rear shock. OC , CA ProjectV8Runner For Sale: Suspension/Wheels/Tires 4 10-11-2015 01:06 PM
