anyone running allpro offroad rear 3.5'' springs?
rnb754
anyone running allpro offroad rear 3.5'' springs??
if so, how much height did you get from the lift?
just looking to get a 3-3.5'' lift in the rear
thanks
russell
thanks
russell
Yes. The springs are pretty true to a 3.5" lift for the rear. They are a bit of a pill to install unless you have a shop lift but when there's a will, there's a way. Because of the added lift make note that you will need longer shocks, extended brake lines, and extended bump stops. Check my signature for what I did. I did a lot of research and talked about shock options with Allpro, Toytec, Bilstein, etc before deciding on the Walkers. Has been great with no issues. Smooth ride with and without gear and will handle a bumper well. When that time comes I will probably upgrade to a 2.5" body shock for the peace of mind although not absolutely necessary.
