02-26-2020, 10:15 PM
#886
Originally Posted by 87pony
I wheel and drive in colorado. Several of my 4runner friends, including myself, have sworn off ridge grapplers ever again. they just are not a good tire in snow/ice.
The stock Terra Graps are worse.
02-27-2020, 08:29 PM
#887
How are they in water, Down here in lower AL we get a ton of water and it floods every time it rains.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
02-28-2020, 10:05 AM
#888
Originally Posted by sn_85
can speak to snow beyond what little has been on the street for me over the past couple of years, but they do not suck in the rain.
02-28-2020, 10:15 AM
#889
They are absolutely horrible in deep wet snow, pretty good in dry rocky terrain and subpar in mud. Probably one of the quietest ATs I've ever run (Even quieter than my KO2s) and seem to be easy to balance.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
02-28-2020, 11:04 AM
#890
Thanks ja for the KO2 noise comparison. That was one of the options on the table. Though the TG would have been much more noise. Glad to hear it’s not.
2018 Off Road Premium. Future upgrades: King shocks and FN wheels. Baja Designs fog pocket lights. HID headlight kit
02-28-2020, 11:48 AM
#891
My RG’s on my Jeep were definitely louder than my KO2’s. I’ve always thought the KO2’s were quiet until I came to a 4R forum.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
02-28-2020, 12:03 PM
#892
Loved my Ridge Grapplers when I had them on my Suburban. Thought they were really quiet for how aggressive they look.
02-28-2020, 12:43 PM
#893
Does anyone know how these compare to the yokohama Geolander M/t and X/at's
The Build
03-26-2020, 12:40 PM
#894
I've settled on buying RGs later this year. My current tires still have a bit of tread left, but I'm seeing discount tire has an $80 rebate on these until the end of the month. How often to these rebates come up? Is it worth getting them now or should I still wait? Thanks!
03-26-2020, 08:30 PM
#895
I got these tires from Discount Tire about a year ago. I showed them an ad for the same tires on sale somewhere else and they did a price match. I think it saved about $100. Not sure if that is a nationwide policy, but you could always try that later.
03-26-2020, 09:56 PM
#896
ko2's are so quiet lol. my f250 has RG's and they're 10x louder than the wife's ko2's lol.
03-26-2020, 10:23 PM
#897
They don't. The Ridge Grapplers have a 2-ply sidewall only.
I now run Mickey Thompson ATZ P 3.
They are as tough as any radial tire, at least when new; they are shockingly good on pavement: this includes heavy rain and a mind-blowing for me soft ride despite the LTE rating and the thick sidewalls (with heavy duty suspension, not sure the stock one can cope as well with the weight).
Off-road, they are super strong and can handle any mud we normally encounter in the West. My previous P metric Wildpeak AT3W also had fantastic traction but while they were very strong for a P, they were not strong enough for frequent desert use.
But maybe you do need MT, considering your location.
03-26-2020, 10:26 PM
#898
Do you think it could also be the cabin's insulation? My Outback was louder than my 4R.
03-27-2020, 12:41 AM
#899
Going to give a long term update, since I've worn out a set of 285/75R17 C rated Ridge Grapplers over a variety of terrains. I've since gone on to try a set of 295/70R17 Cooper STT Pros, just got them and they are a very aggressive tire, I've run a lot of tires in and done a lot of wheeling so interested to see how these do. Probably a little too aggressive but I'll see over the coming miles how they hold up.
Anyways back to the RG, for a variety of terrains like how I run I wouldn't get them again. Where these tires worked well was in the dry areas, Arizona, Utah, New Mexico, sandy areas. I'll break down the different categories so people can have an idea of what to expect.
Rocks- They held up well, the more boulder type stuff they did good. I wouldn't say they were bad by any means. They did chunk a little on slick rock but not losing full lugs but they did lose a bit. Northern pacific rock terrain they definitely left something to be desired. There is one large rock slab on the Whipsaw that I just couldn't do, even running around 15 psi of pressure and having massive flex. Took multiple attempts and even gave them some spinning on the rock to heat them up to get a little extra grip, and even so it was a no go. Eventually after multiple attempts instead of potentially rolling I took the bypass. I've made this obstacle easily in the past in a Tacoma (Very different truck but also have seen other vehicles in my group make it without as much struggle) For the northern type of terrain it was kind inconsistent what to expect, sometimes a tricky obstacle wouldn't be a problem, the next it was interesting to wonder why it was such a struggle. One minute looking like a hero the next a zero pulling cable.
Sand- They were awesome in sand. Had good traction and flotation. Never really dug down unless being silly but they worked well here.
Desert- Never had a tire failure or any problems going through the harsh desert roads and sharp rock terrain. In fact my only puncture was from a nail that I pulled out and plugged. No sidewall slices or anything like that. I was impressed.
Snow/Ice- Well... lets just say this is where they fall straight flat on their face. In the snow even when new they were terrible, it wasn't that they clogged they just wouldn't dig in the snow, powder, heavy wet snow, crusty snow they were just absolutely terrible. Rather than keep chewing forward they would stop and polish and that would be it. Even running around 10 psi. Different driving techniques from full on rev limiter second gear limit assaults to crawling to try and stay on top of the snow. They were just bad. And as far as ice goes they weren't the best. They seemed to handle a lot like a full blown mud tire and missed the mark with the hybrid tire and ended up closer to mud terrain tire handling than all terrain on ice. If you're looking at this tire as a compromise for winter conditions from a full on mud tire don't, you give up the benefits of the added mud tire traction for nothing when it comes to ice and snow.
Mud- They worked okay, the outer lugs were what kept the vehicle moving forward. The center plugs up quickly, the outers will as well however can give them a little spin and they clean. It's obviously not a mud tire so don't expect it to be one, but it was okay.
Highway- I really have no complaints about these on the highway, I didn't notice them being overly noisy and they didn't have bad vibrations. Didn't hydroplane in Texas/Oklahoma downpours. I also took it a little easier knowing that they are terrible on ice.
I think I put roughly 80,000 kms on these tires. But they were done, some cracking between the lugs and near bald. I normally don't run tires to the point that I ran these. So hopefully this helps those looking into the Nitto Ridge Grapplers.
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
03-27-2020, 07:56 AM
#900
Originally Posted by canadian bum
Going to give a long term update, since I've worn out a set of 285/75R17 C rated Ridge Grapplers over a variety of terrains. I've since gone one to try a set of 295/70R17 Cooper STT Pros, just got them and they are a very aggressive tire, I've run a lot of tires in and done a lot of wheeling so interested to see how these do. Probably a little too aggressive but I'll see over the coming miles how they hold up.
Thanks for the review. This is really similar to my experience with the same tire (size and rating). Although I stopped short in mileage compared to you. (40,000, 7/32 left. Some splitting, sipes mostly gone)) I ran a set of 305/70 E's after the 285/75 C's and they were considerably worse in snow and ice and overall rode much rougher. One was completely out of round so I only ran them for a few thousand miles before I tried to warranty them back to Nitto who refused to do anything for me. I'm on Cooper St Maxx's now in 285/75 and they are remarkably better all around. Especially in snow and ice
