Daystar/Toytec Lift Tire Size
tko125
I seem unable to find a clear answer regarding max tire size w/o rubbing on either the Daystar or Toytec 3" Level/Lift Kits. I currently run 275/55/20 Nitto Terra Grappler G2's which work flawlessly on my 2010 LE w/o rubbing.
Before I install a level kit I want to ensure that these tires won't be dwarfed or rub.
Could I have gone with 275/60/20's with the level and had no rubbing (I know this wouldn't have worked with stock XREAS)?
Will the 275/55/20's I have now rub with the level/lift since the wheel well is going up and the angle changing with the fender/liner? I've seen some people with the daystar kit running my tire size but using wheel spacers which I don't want to do.
Thanks in advance.
