Dobinsons 2016 4Runner Trail Build
Oh wow. That's fantastic looking. How much does it weight? When is it going to be available? How much $$?
I like how simple and tight it fits against the body. Seems to stick out quite a bit less than the ARB does.
Thanks man. Weight is probably 120 like the Tacoma but we haven't weighed this yet. Need to build enough interest and take some pre-orders before confirming the delivery time. It would be $1150 raw plus shipping if we move forward with it.
We aimed for it to be as close as possible. And high too.
Sent from my SM-G930V using Tapatalk
Front flex?
I was JW.
When you guys had the 4runner on the ramp or fork lift was the front coils on the coil over at bind or was it just the sway bar not allowing the driver front tire to push into the fender well?
Your guys stuff will be under my rig sooner than later, just locating $ and a solution for KDSS rear with your LT set up.
I was JW.
I don't remember to be honest. On the ramp, I don't think we were able to reach maximum compression on the front, there wasn't enough pressure/weight on it to get it to fully collapse. I don't think we would have hit coil bind either before the strut would bottom out and the bump stops would engage.
What is the height front and rear in these pictures (either hub to fender or fender to ground) and what springs?
That stance looks good!!
The front coils are 448 and the rears are 675v. Front is at 3" and rear is 3" also
Front High clearance bumper makes it look tall too.
Today we took the top hoop off the bumper to take some photos and get some feedback. At this point, we haven't had enough interest to put this bumper into production, unless that changes with this post. Take a look at the before and after pics of the bumper with and without the tube and let me know what you think. It would be $1150 raw, plus shipping if we did make it.
Took the 4Runner and Tacoma out yesterday for a bit of a play around and got some more photos too.
I really like the bumper with or without the hoops. I would make it an option for either.
I also would suggest you make a post specifically about the bumper and try to see what interest is after a dedicated thread about that. I dig it though. Only gripe would be that it needs rated recovery points on there. That would +1 you on the ARB one.
Guys, we're selling that front bumper off that truck. The truck is going up for sale soon, so no reason to leave it on. If anyone is interested, please let me know and we can work out a deal for you.
