King Shocks & Lift Advice: Springs, Sway Bar Links, and anything
MtnClimbr
Junior Member
I have a 2018 4Runner TRD Pro that I'm about to upgrade for off-roading.
Already ordered:
• Fronts: King 25001-133A-EXT (Kings arrive mid/late June)
• Rears: King 25001-125A
• Control Arms: Camburg Kinetik V2 Billet
• Panhard Bar: Icon 54200
• High-Clearance Bump Stops: DuroBumps
- Front: DBF212
- Rear: DBR425
I have BFG KO2s 275 70R17 with about 5k miles. I installed these 3 years ago but was busy with family and moving. I will stick with these for a year then move them to the family car which will need new tires next year: 2023 4Runner TRD Pro Solar Octane.
I'm happy to hear suggestion for next year 285 70or75 R17? We can put a pin in this for now.
I'm pretty sure about the following:
• Brake line: TCrown Performance +2″ Brake Line Kit, 2003-2024 4Runner, Front And Rear: https://accutuneoffroad.com/product...ke-line-kit-2003-2024-4runner-front-and-rear/
• Castrol SRF or Motul RBF 600 brake fluid
• Needle Bearing Replacement (ECGS Bushing): East Coast Gear Supply (ECGS) Bushing TOYOTA 8" CLAMSHELL CV AXLE BUSHING
Questions:
• Extended Rear Saw Bar Links:
- Dobinsons Model SE59-529 or
- Redrunner Designs or
- OCD Forged Ball Joint Sway Bar Links
– Overland Custom Design
• Springs: I don't have added weight of a rooftop tent or drawer system. I will have gear for 1-2 nights max or day trips. Hi-Lift jack. Buying a Powerbuilt bottle jack & jack stand. Portable jump starter. Whatever else I should carry...
- Light: Dobinsons C59-325 or Icon 52700 (dual rate) or ?
- Medium: OME 2889 (probably only if I add more weight?)
Do I need the following:
• Front sway bar relocation brackets for the King shocks or does King include those?
• 2003-2024 4th/5th Gen 4Runner Panhard Correction Kit (PCK) 2003-2024 4th/5th Gen 4Runner Panhard Correction Kit (PCK)(R) I already have the adjustable pan hard bar. Do I need to correct the angle?
• Rear Spring Spacer to correct the 4Runner lean? ARB Old Man Emu Rear 10mm Coil Spring Spacer for Toyota 4Runner. PART NUMBER: OME150PR10
Please also chime in with opinions if I'm wrong where I'm sure...
I'm price matching everything I can across sites as I see deals appear. Can I expect Memorial Day sales on anything I have left? I have about 2 months until the shocks arrive to assemble everything else I need.
Deka
