wfo9
From my experience... if you have fixed UCAs it is simple. Go as high on caster as you can without throwing off camber.So what is ideal caster for a lifted 4Runner? Where I had mine aligned, their specs said about 3.3 was "dead center" which is exactly where they set mine. It looks like the max it can go is 4.10 while still being in the green..
If you need to error on one side or the other... More + is clearly better. The only time you can really get too much caster is with adjustable UCAs. 3.5 - 4.0 should be a general target. I would not trust the machines all that much though. they all measure different numbers in my experience. And like I said.. even with aftermarket fixed UCAs and a 3" lift... you won't be able to get enough + caster to cause any strange handling. With stock UCAs it is typically impossible to get enough, but there are those oddball trucks that do.
