Is there a frame mounted step slider?
Nick800
I've been looking for a frame mounted slider that has a drop step. I know this would present some draw backs of reduced ground clearance.
Is there such a product?
Thank you
Sliders are designed for the higher clearance. So chances of getting one with a drop.. Is slim to none. Could possibly get them to do a custom job for you.
SSO might mount to the frame. That's what it looks like in their picture. Still waiting for mine.
It would have to be a custom order. I would suggest find a base slider/company and ask them about adding what you want to it. Maybe buy a basic bolt on slider then buy some nfab rkr rail steps (same ones found on the tforce 4runners) and bolt them up to the slider? That way you could remove them for off-road use.
Yes look the same but just the steps - I thought they were 70/pair then
N-Fab Nerf/Step:Bolt On Detachable Step (PAIR) - N-Fab Rock Sliders & Steps - Jeep Skid Plates
To the OP - did you reach out to any of the companies on the forum? There are some really great people and I'm sure one of them would love to try out a new design
Rock sliders versus a step
forgot that proline had this
https://proline4x4.com/shop/side-steps/toyota-4runner-14-side-steps/
This might be what you are looking for. They are frame mounted
These Proline steps aren't rock sliders. They are steps mounted on a rail. It doesn't look like they offer any protection for the rocker panel, mostly due to the steps that hang down low. Most steps are counter productive to protecting the rocker panel.
Most good rock sliders, Domello, C4, BudBuilt, Shrockworks, RCI, White Knuckle, Sonoran Steel, etc. all serve double duty as a rock slider and a step. These all offer a narrow step but they work for a step up into the truck. My Domello rock sliders sit just below the floor level and serve as a good step.
seltzernator
