Motor Mounts
bwallick
Junior Member
2000 Toyota 4Runner SR5 3.4L Auto 4WD
Replacing motor mounts and found the driver's side frame mount has been fractured. The piece which welds to the frame should have two ears to fasten the motor mount to, but as you can see in the photos, the driver's side has been damaged.
Local dealer says they do not sell that part. I'd like to confirm that with you because I've never used the dealer before and don't know if this is trustworthy info.
I want to fix this while I have the engine half apart (head resurfacing and gasket job) so I can't drive it anywhere.
I may have to cut the part out of a junkyard vehicle and get it welded in place in my garage.
Does anyone know a good mobile welder in the Boise area?
edcultural
