Originally Posted by 3wbdriver
Your rack is new enough it will have the upgraded feet. You can expect some crushing of the weather seal over time. Mine was on there for 3 1/2 years before I pulled it to install one from SSO. I had no issues with leaks even using the older feet, and all of the seals were pretty much flattened. You may try to see if you can tighten the bolts that little bit to allow for the settling of the seals. Probably won't even take 1/4 turn. And as always, despite your description, a picture is worth a thousand words.
The issue was the feet pressed on the roof skin and dented it, not a seal.
