Old 02-12-2019, 06:15 AM #1
TRDTommy's Avatar
TRDTommy TRDTommy is offline
TRDTommy will become famous soon enough
TRDTommy's Avatar
KDSS front sway bar replaced...
So my front sway bar was replaced under warranty because of one of the bushings under the KDSS cylinder getting loose and separating. I took my truck in to point out the issue back in December. And here we are now that it is February. It took a whole bunch of calls and messages from me to get this repair rolling. But long story short this is the outcome.
Now after they replaced the whole sway bar. Bushings look good. But I noticed the end of the bar on the passenger side comes out farther from the bracket compared to the driver side. The driver side is a lot shorter. I'm just wondering if this should be something to be concerned about. I imagine on road driving doesn't move the sway bar too much. But what concerns me is off road driving once the suspension and sway bar starts moving and articulating a lot more. Any thoughts, or am I overthinking it and worrying too much?
KDSS front sway bar replaced...-20181213_113618-jpg  KDSS front sway bar replaced...-20190212_003749-jpg  KDSS front sway bar replaced...-20190212_003847-jpg
2017 MGM TRD ORP w/KDSS
TRD Pro Wheels - 275/70/17 BFG KO2 - Spidertrax 1.25" Wheel spacers
Kings shocks w/front and rear adjusters, Icon Delta Joint Tubular UCA, Dobinsons rear coils
Sherpa Crestone roof rack
TRDTommy is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 07:13 AM #2
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Overthinking it..
If it rides good without clunks let it be
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 10:24 AM #3
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
That bushing is $8. I've replaced mine proactively, as well as the bushing on the fixed side, and the bushings where they mount to the LCAs.
I can't fathom why they would replace the entire swaybar.
I think you might be surprised how much the swaybar moves around in all directions. That gap may very well appear on the other side at some point.
No worries. As mentioned above, if it's quiet, no problem.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 08:44 PM #4
TRDTommy's Avatar
TRDTommy's Avatar
Thanks for the replies. It puts my mind at ease now. I was also wondering why they had to replace the whole bar and I told them just to replace that bushing. But they insisted that the bushing and the whole sway bar had to be replaced. Which kinda ticked me off since I was without my truck for 4 days. Oh well. Its fixed and hopefully no issues. Now I can finally put my Kings on!
Old 08-01-2019, 08:38 PM #5
JPK_NJ JPK_NJ is offline
JPK_NJ is on a distinguished road
Bringing this back up to see how the fix is holding? I have 2019 ORP w KDSS and had the front side KDSS cylinder bushing replaced at 500 miles because the occasional knock sound (primarily when cold). It's going to dealer again now at 2500 miles with my replacement bushing torn exactly like yours in the first pic. Curious to see what they try replacing this time.
I've also been running C rate K02s (255 70 17) since day 1 and Im kind of thinking the stiffness is messing with the KDSS somehow. Making it take extra force it wasn't designed for maybe?
JPK_NJ is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 12:24 AM #6
No.
Old 08-05-2019, 09:03 PM #7
Well chalk me up as another 19' KDSS issue. Since my initial dealer fix didn't work, driver side bushing replaced at 500M, they're now planning on full sway bar/bushings/end link replacements.
2500 miles on truck but have had C Rated BFG K02 tires since day 1. Something about it just makes think stiffer tires are causing extra force/stress on the suspension components that were engineered with the give/flex of P rated rubber.
Hoping other member with KDSS problems can chime in and indicate what tires they're running. I might go back to P rated tires when my truck is hopefully fixed on Thursday.
Old 08-05-2019, 11:57 PM #8
E rated tires on 2.5" lift zero issues other than occasional squeak from the bushings where it bolts to the LCA...makes sense as they're at an angle they weren't designed for.
Old 08-06-2019, 10:59 AM #9
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
It's definitely not tire related. I'm pretty sure I've put a lot more stress on my end links than you'd get from just having a stiffer tire. I've taken mine out jumping in the desert. Rock crawling. Etc. I've even bent the rear fixed link by dropping it onto a big rock. Bushings are still good at 50k. The only think I've noticed is that the metal straps that are supposed to help hold the bushings on have come off. But other than that - no issues. The folks who are running 20" wheels with lower profile tires have harsher ride than putting on E rated 17" tires. So for example all of the GX's will have firmer tire/wheel combos than an E rated 265/70/17.
Old 08-06-2019, 11:52 AM #10
Thanks for the reply. Puzzling that I've had these KDSS issues at 2500 miles and the only change from day 1 was going with a different size tire than stock. Jumping up to 255/75 C Rated K02 instead of 265/70. I had a 2016 Trail (always stock tire size) for 3yrs before "upgrading" to this 2019 w KDSS and never had any suspension / balance problems at all. Super frustrating
Old 06-19-2020, 12:09 AM #11
sabom_matt's Avatar
sabom_matt sabom_matt is offline
sabom_matt is on a distinguished road
sabom_matt's Avatar
KDSS cylinder failure
Have had an Icon stage 2 lift for ~2 years with ~15k miles on them, with a few moderately difficult off road trips. Recently developed a clunk front drivers side. Diagnosed as the KDSS hydraulic cylinder. Vehicle is currently at Glendale Toyota in Los Angeles area. Dealer won't cover under warranty.
The service manager defers to the "field tech specialist", who just consults over the phone and decides to deny warranty.
I then created a case with Toyota Customer Experience, and they have also allowed that decision to stand.
My 4runner is currently in their shop with a dismantled KDSS system, and the hydraulic cylinder unit (only comes as a unit with lines) costs $2046!! And they want to charge $2000 on top of that for diagnosis and then installation. I could almost get an Icon stage 7 for that amount!!
I am almost furious enough to get a lawyer involved, but not sure that will be worth my time and additional costs.
From reading through a couple other warranty threads, it would seem the burden of proof would be on Toyota to make the case that my Icon lift CAUSED the KDSS failure, and they have not done that, nor do I believe they would be able to do so.
Any suggestions would be welcome.
sabom_matt is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 01:55 AM #12
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
A lawyer would almost certainly cost more than you repair bill you've noted. A lawyer is going to charge $500 to $1,000 minimum to even open a file and submit some sort of demand letter and it's gonna go up from there. I think Toyota would have a pretty good case to state your lift affected KDSS somehow. I know tons of us have lifts with no problems with KDSS, but you deliberately changed the suspension from stock and KDSS is a pretty big part of the suspension system. They'll say you modified it outside of its designed parameters.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 09:32 AM #13
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Same here on the metal strap.
Regarding those in the Gulf States where Toyota doesn't stock KDSS (you have to order one if you want one) you may be better going to a Lexus dealership since GX's all have KDSS and mechanics should know how to work on them.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 06-19-2020, 09:58 AM #14
sabom_matt's Avatar
sabom_matt's Avatar
I suppose I am still in denial about the cost on this. If it were only $1k I wouldn't think twice, but $4k seems outrageous to me, especially for a Toyota. I think I will try negotiating with the dealership that I actually bought the vehicle from to see if they could cut me a break, or maybe price out a non-dealership mechanic.
It's also frustrating that I see no evidence of anyone else having this failure of their hydraulic cylinder on this forum. Makes me think it really is a manufacturing default.
Old 06-19-2020, 12:59 PM #15
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Are they 100% sure cylinder is the problem? When my bushings wore out I developed a clunk. Replaced bushings and clunk gone.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
bar , replaced , road , side , sway
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences. CS223 5th gen T4Rs 60 12-08-2021 06:48 PM
KDSS sway bar bushing fell out a t l a s 5th gen T4Rs 3 11-28-2021 11:26 AM
Hello all, KDSS vs beefed up sway bar question Helixx New Members 3 09-17-2018 12:07 PM
Replaced rear sway bar bushings, already squeaking 5 days later Supermoney 3rd gen T4Rs 10 04-26-2017 11:07 PM
** HELP PLEASE ** KDSS sway bar reconnect trouble!! optik 5th gen T4Rs 9 02-11-2013 12:07 AM
