Old 04-30-2021, 10:01 AM #1
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Tap Size Needed
I will be re-tapping my skid plate bolt holes this weekend. I would also like to re-tap the front small cover bolt holes that is under the radiator/bumper. there are 5 bolts and a push pin. It's the cover you take off before taking the skid plate off. does anyone know what size tap I need for those holes? I already know the regular skid is 8x1.25.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 11:51 AM #2
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I used 6mm-1.00. But...when checking the 6mm-1.00 die on the brand new bolts they’re not as smooth as I’m used to while working with good quality machine bolts. Probably just the finish they use.
Tap Size Needed-84930f56-5c03-4784-929e-4f17ed90a2cf-jpg
1000MPH is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 12:04 PM #3
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Like @1000MPH said, M6 x 1.0mm.
Old 04-30-2021, 01:02 PM #4
Jivewalker's Avatar
Jivewalker's Avatar
Great, Thanks!
I am fragile.
Not like a flower.
But like a bomb.
Old 04-30-2021, 03:29 PM #5
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Skid Bolts are M10 X 1.25
Best Regards,
Saker
Old 04-30-2021, 06:02 PM #6
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Re-tapping aint really a thing taps are for cutting new threads. You should use a proper thread chaser/restorer unless the threads are totally wrecked.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 06:09 PM #7
Saker's Avatar
Saker's Avatar
Yes this is correct.
The only reason I recommend taps for the skid bolts is because I found them to be really fouled with debris.
Of course YMMV.
Best Regards,
Saker
Old 04-30-2021, 07:07 PM #8
1000MPH's Avatar
1000MPH's Avatar
Found this set on Amazon I didn’t know I needed until now.
Amazon.com: Lang 6 Pc. Metric Thread Restorer Tap Set (LNG-2588): Automotive
Old 04-30-2021, 08:19 PM #9
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
Chasing threads is a good job for Harbor Freight taps. That's about all they are good for.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 08:56 PM #10
Just dont snap one in there. I need to figure out how to drill out an EZ out I broke in one of the skid bolts a while ago after too many beers and too little patience yay.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-30-2021, 10:07 PM #11
Tungsten carbide is your friend, sans the beer this time around. Good luck.
2007 FJ
Old 05-03-2021, 08:16 AM #12
Jivewalker's Avatar
Jivewalker's Avatar
Ok, didn't check back on this thread after someone gave me the bumper cover screw size and I wish I had.
Here is where I landed. I ran ( cheap HF ) dies on each bolt (5) @ M6x1 and and I had (4) new bolts for the main skid. Dies cleaned up the bolts, or maybe they just cut new threads, no idea but i kept on going.
Next, I ran the taps (cheap HF) up through each hole. Wasn't real easy or real hard and shavings were coming out. After each hole, I finger tightened a new bolt up into it to make sure the bolt would go. I thought they felt a bit loose, but kept going.
Here's where I'm not to happy. I could tighten 2 of the skid bolts to what I thought was tight enough, but not they other two. They are stripped again. I also found that the bumper cover bolts were similar.
I want to re-tap all of the holes for new bolts one size up. I looked at some tap and drill charts, but I'm confused. Can someone give me the proper method for finding the next size so I can get the skid solid again. I will buy good taps and a good tap handle as the HF tap handle really sucked.
I'm almost ready to just drive some self tappers in there.
I am fragile.
Not like a flower.
But like a bomb.
Old 05-03-2021, 11:32 AM #13
1000MPH's Avatar
1000MPH's Avatar
Well that sucks! I’ve got one that I can only hand tighten, it was stripped after my first visit to the dealer.
Since you need to be careful with these anyway, I personally would try helicoils first, or maybe these knock-offs...
Amazon.com: Highking Tool Thread Repair Kit, M6 x 1.0mm Thread Repair Insert Kit Compatible Hand Tool Set for Auto Repairing (M6-1.0): Automotive
In case you need new bolts part numbers...
SKID PLATE BOLT 9008011373
LOWER COVER BOLT 9010906330
Old 05-03-2021, 12:20 PM #14
Saker's Avatar
Saker's Avatar
Repair kit for the TRD SKID PLATE BOLTS = Supercrazy Alltooetools Thread Helical Coil Repair Tool Kit M10 X 1.25 SF0059E
The skid plate bolts are kit # PT938-00140-AA
Look at the first 2 items on this page:
2019 Toyota 4Runner TRD Pro Parts like Skid plate
Best Regards,
Saker
Old 05-03-2021, 01:06 PM #15
Jivewalker's Avatar
Jivewalker's Avatar
Yep, looks like I'm might try the helicoil as it's much cheaper than a good tap.
I am fragile.
Not like a flower.
But like a bomb.
bolt , holes , plate , size , skid
5th gen and 3rd same hub size? hubcentric rings needed? Jeremy107 3rd gen T4Rs 8 01-12-2019 09:21 AM
5th gen and 3rd same hub size? hubcentric rings needed? Jeremy107 3rd gen T4Rs 1 01-08-2019 07:54 AM
Tire size help needed! Jduv10007 3rd gen T4Rs 17 09-16-2014 10:13 PM
Zerk thread size needed ecally 4th Gen T4Rs 0 08-11-2012 10:26 PM
Tire size help needed! evmenke 3rd gen T4Rs 9 08-19-2011 08:33 AM
