ElectroBoy
Banned
After several long distance trips this spring through CA, AZ, and UT I got tired of cleaning the bugs and butterflies out of my radiator fins when I got home. Frequent cleaning of the windshield and front end is expected during bug season, but removing the plastic cover to access the radiator to vacuum and scrub the fins with a toothbrush and toothpicks is a pain. Plus it’s possible that severe clogging could result in the engine running hotter than normal. So I got some black nylon window screen material, 0.125 in black splining and rigged up some protecto-shields for the exterior surfaces of the front grill.
For the large section I cut a piece of screen approximately 37 x 7 inches and tucked it in around the edges with the spline using a small flat blade screwdriver. It’s a snug fit but it works. Using a cardboard pattern, I cut out the two small screen sections and spot tacked them to the grill with black E6000.
I’m not sure how long this will stay put, but so far it’s holding up well. The bugs easily brush off and the radiator stays clean.
