08-12-2018, 04:23 PM
Rear diff breather
This may be a stupid question. I am brand new to the 4x4 world. I noticed people with TRD pros an trails adding a rear diff breather. Is this something I can add to my SR5?
08-12-2018, 04:31 PM
Real Name: Chris
Real Name: Chris
Yep, all the same and if you're going to wheel it in water it's a very good idea.
08-12-2018, 04:32 PM
If you plan on off-roading that involves water crossings, not a bad idea. If you're going through puddles in the mall parking lot, probably not.
2020 TRD Off-Road MGM
08-12-2018, 04:34 PM
Lol thanks! Definitely for off road use.
08-12-2018, 04:35 PM
Real Name: Chris
Real Name: Chris
Here's what I did
08-12-2018, 04:36 PM
Yes it is.
Rear Differential Breather Mod For Dummies
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
The stock breather has a little check valve inside. The idea is to let air out as the diff heats up and the everything expands. When you hit a nice pool of cold water it immediately cools down and pulls the valve close. However, if you do the auto equivalent of a cannon ball into a deep hole you get water over top of the breather before it has a chance to close the valve. In that case you can suck in some water.
Previous post said it best. If you're crawling the puddles on the way to the mall you don't need it. If water came over the hood your last time out and you're considering a snorkel, then better get it.
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
Real Name: Chris
Real Name: Chris
Couple more
08-12-2018, 04:50 PM
Real Name: Dave
Real Name: Dave
Diff breather kit
Here's what I did. Just slightly different than what other have done.
I ran the tube up into the gas cap area. Another option is the ARB filtered diff breather kit in the engine compartment with the tube run along the frame to the breather. You'll find the link to the breather kit in one of the links here.
You won't have the E-locker valve on your SR5.
E-Locker and Differential Breather install, Trail Edition
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
08-12-2018, 05:36 PM
I asked this question awhile back, but got no response. Does this one not work well?
Trail-Gear Creeper Breather - Differential Breather Kit https://www.amazon.com/dp/B008OLPUJS..._vFkCBbX6A1HWR
Vietnam 67-68
08-12-2018, 06:43 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
08-12-2018, 07:14 PM
Originally Posted by RedSled
I have never used one like that, but it may work.
I would rather have the diff without vacuum on it from temp changes during a water crossing. With the diff mods with out valves ( & using filters) it stays at ambient atmos pressure.
Best Regards,
Saker
08-12-2018, 07:20 PM
Thanks for the reply Saker, that does make sense.
Vietnam 67-68
07-31-2019, 07:46 PM
So how big do you guys consider puddles at the mall?
I plan on doing the ARB breather tube mod.
Today monsoon hit, streets were flooded however, puddles were like 8 inches deep. Everyone was going through (even 350z, sedans) and i was like well, I can't look like a ***** in my new 4runner. It was not enough to cover the pumpkin, but maybe if a spash or two were to go over the stub breather, would that be bad? Would i need to worry about it?
07-31-2019, 08:30 PM
Banned
Real Name: Tobias Fünke
Banned
Originally Posted by 2016 4Runner SR5
Couple more
I did this except I have two lines. One for my Elocker and one for the diff.
OP don't waste your money on the arb kit. It is no more functional then this and I cringe everytime I see someone stoked about buying that kit.
