Clean rear dashcam mount
Ok, BlackCamBracket(TM) v1.1 is a thing
Increased the neck height to there’s no need for washers and it has 2.2° of angle so the camera is axially level when mounted.
New hotness on the left. Old-n-busted on the right.
Add me to the ever growing list of people who would gladly pay for this mount Dr. Monkeypants! Please send a PM to work this out if you ever see this message.
Know this is an older post but it was helpful for me. For those of us that do not have or have access to a 3D printer this might help.
I tried to figure out what I could use as a mount like the gents who created the plastic piece in the clean installs above. Somehow a moment of genius was granted to me.
Glock magazine floor plates make a perfect mount for rear webcams. In this case I used a Glock 3941 (10mm) plate but any double stack floor plate will work. If you don't have any they can be had for $1-$5 on eBay and Amazon.
All I did was drill it out, with three holes close to each other. I then used utility knife to remove the thin pieces to connect the holes. Optional as I'm OCD is I used a small Dremel cone shaped grinder bit to clean up the resulting hole. I used this large hole as the wire feed through
I made a hole about 3/4" in front of the center headliner clip (toward the hatch) , just a very small X with a small utility blade will do it. You can also use the center clip hole if you do not want to do any cuts in your headliner. I made the extra hole so I could use the clip to hold up the headliner, again, OCD.
After feeding the wire through the floor plate, I used an M4 socket head screw, think I used a 12mm length but there is a lot of room above in this spot. I used a small split washer as I screwed it from the plate. Above where it came through the headliner, I used another split washer and a flange screw to tighten it down.
I then used wiped the plate with isopropyl alcohol and peeled the sticker off the rear camera and stuck it on the plate. Looks super clean and is working perfect. Thought I would pass it on.
I am purchasing a 4Runner this month. I have a rear blackvue camera that I need to install. If you are still on here, can you please send the correct file I need to make this. Thank you!
