My 2010 just hit 115k and I have zero interior creaks or rattles except this:
I am getting a ticking/rubbing noise coming from where the windows seal against the rubber window seals.
Its as if the texture of the tint doesn't rub smoothly against the rubber seal and creates a creak/tick. I've cleaned the glass-runs and sprayed silicone lube all along/inside the seals and that doesn't seem to help. Its the worst on the drivers window. I can tell its the seal because if I just barely crack the window the sound goes away.
Has anyone experienced this? My next step would be to get a really light grease and apply it in the window seal/glass run.
__________________ 2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
