FJ Cruiser shift knob - No cutting or trimming!
emmantik
Instead of trimming the shaft or taking off the bottom piece of the shift knob, I simply inserted a socket set screw into the shift knob prior to install. It gives just enough space to clear the side of bezel/console when shifting out of park. I used socket set screws, metric M8 x 1.25 x 10mm purchased from our local hardware store. Cost under $2.00 for 2pcs. (only 1 required for this mod, allen keys not included).
I just recieved my FJ shift knob and installed without spagers or cutting and do not see an issue with the fit or clearance. It's gtg as is. Am I missing something?
The issue is when you shift out of park. The bottom of the shift knob hits/rubs against the bezel/console.
I went with a 6mm set screw. I’m guessing anything longer than 3mm would suffice.
Thanks [MENTION=79050]emmantik[/MENTION]
Same here. I just threaded it on, no spacer no cutting needed.
It's definitely cooler looking and just the right height to rest my hand on from the center console while driving.
I've thought about getting one of these, even though my Pro came with a TRD shift knob...which is quite homely. Really, if the TRD is the "fancy" one I'd hate to see the regular. It looks like it'd be more at home in a Sienna minivan.
If you do take off the TRD shift knob you will lose HPs. :bluejump:
If you get a FJC shift knob, there are enough people out there to buy your TRD shifter you could make enough to buy beer! :cheers:
BTW I had to my FJC shift knob, I used a mitre saw and still have not found the shrapnel after it shot off the blade.
Yep...
I'm just chiming in to reconfirm that this mod works beautifully. I ended up using an M8 - 1.25 x 8mm set screw (it's just what I had on hand). Worked perfectly.
I originally planned on using a dab of red Loctite, however after seeing how easily the stock shift knob came off... I didn't bother.
I broke off a piece of pencil and achieved the same thing. FO FREEEE!
Yes get the matching T Case shifter, it's how the trucks should have came IMO.
Yeah some of the earlier models had the back t case. IDK why they got away from that. Automakers think fake chrome and silver paint makes things fancy.
My '15 had a silver t-case knob, so when I did mine I had to buy a black trans and a black t-case knob. They do make a silver trans knob if you prefer to match that way, as well.
lindwlson982
