Pre 2020 TRD Pro grill on newer 4Runner with TSS
adrtoy
I have a pre 2020 OEM TRD Pro grill setup and was wondering if the TSS would be in the way if I wanted to use it on a 2020?
You'll need to dremel areas out of the middle section to fit the TSS sensor. The 2020 Pro grilles have the area notched out already.
It's doable but you will need to dremel some parts of it to make it fit. Someone on here has done it to their 2020, but I cant remember who.
on top of trimming the long black nameplate plastic part a bit for the TSS sensor, you will need to do two mote things
(1) cut two or three tiny holes in the bumper wherever the GRILL's locking tabs don't lock into the bumper. i did this with a sharp haxoknife. very easy
(2) buy two brackets if you do not want to do custom cutting of the radiator grill bracket. parts 53115-35050 and PZ327-35701
attaching pics for reference
Additional parts required for install on a 2020 using 2019 and before TRD PRO Grille
Radiator Bracket - 53115-35050 $41.43
Radiator Bracket - PZ327-35701 $28.35
or
2020 TRD PRO Grille
Garnish Front Bumper - PZ323-35058 $287.92
Grille Radiator Up - PZ327-35056 $113.59
Can you please elaborate on the parts needed for a 2020 runner ? I’m lost :( my dealer wants 2238.32CAD FOR 5056 , 5701 and 5058 parts :( thanks
2020 TRD Pro grill to 2020 Limited
Hello. I'm creeping an old thread here. I cannot seem to find any solid info on this anywhere (I know, everyone says that).
I have a 2020 Limited. Does anyone know if the 2020 TRD Pro grill would be an easy (no cutting) swap? It seems the 2020 Limited shares the same bracket components as the TRD Pro (pls see attached pictures). But surprisingly I am not finding any info out there of anyone doing a 2020 to 2020 swap from a TRD Pro grill to a Limited. Cheers.
Did you ever find the answer?
Holy :toilet: I hope quoting your post sends a notification to your email or something since I know it's been a while since you posted that.
Does that price include installation? Even still, that's steep. I don't know what these parts would cost in Canada, but goodness.
Anyway, these are the only parts you're going to need if you're staring off with a 2020 which means you won't need to mix and match pre-2020 parts.
PZ323-35058 Garnish Front Bumper
PZ327-35056 Grille Radiator Up
Watch this video TRD Pro Grille Install for 2014-2019 Toyota 4Runner - YouTube and read this topic Grill upper/TRD pro heritage grill installation info (2020) for good detailed instructions on how to do it and some extra pointers I figured out while doing it myself this week.
Did you ever get this done?
Philthyphilthy
