Old 09-08-2021, 07:09 AM #151
Sconnie's Avatar
Sconnie Sconnie is offline
Sconnie will become famous soon enough
Sconnie's Avatar
I will soon be purchasing a set of Toyo AT3 in the stock size and P load range. Will I need to have these road force balanced? Or should I just have them mounted/ standard balanced and see how that is? Whats everyones expert opinion on this?
2021 4Runner Trail Special Edition Midnight Black Metallic
Sconnie is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 07:58 AM #152
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I don't think road force balancing on a larger tire like on the 4R is worth it unless you are still having problems after a normal balance. usually, at that case it is probably a problem with the tire itself.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 12:21 AM #153
alxdo2 alxdo2 is offline
alxdo2 is on a distinguished road
Installed!
Thanks everyone for all the advice in the thread! I recently got the 285/70/17 P Rated AT3 installed with the Westcott Pro Lift Kit. After install, road force balance, and alignment the vehicle actually drives better than stock when I picked it up from the dealership two weeks ago.
Toyo Open County AT III (AT3)-dsc02707-jpg
alxdo2 is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 07:43 PM #154
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I hope you have better luck with them than I have. 22k miles later almost to the wear bars and they are so chopped they sound like an old set of swampers. Alignment is good and I rotate every oil change. I'm going back to BFG's.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 08:41 PM #155
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
What size, load range, and pressure did you run? How many miles do you run between oil changes (aka tire rotate for you)?
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 06:25 AM #156
SL load 285/70/17 at 35PSI and rotated with every oil change at 5k miles. 23k miles on the tires and they are absolute junk. I've been buying truck tires for over 25 years and these were the worst purchase yet. Of course I started out with Falkens that they wound up buying back because only one of the 3 was actually round.
Old 09-21-2021, 08:06 AM #157
osugsxr osugsxr is offline
debated b/w these and the bfg ko2 .I went with BFG ALL-TERRAIN TA KO2 LT265/70R17 LRC RWL ALL TERRAIN from costco about $900 OTD installed after coupons. BGF solid reviews and do like the look of them and limited off road use.
Old 10-01-2021, 02:38 AM #158
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Originally Posted by BlueRidge77 View Post
I just had SL 285/70/17 AT3s put on today. No real testing except interstate. They were very quiet. A slight whine at 70 mph (had to listen for it, even the AC fan on 3/4 would drown it out…) but much quieter than my worn out SL 265/70/17 Falken AT3W which had 60k miles on them. (They were a great tire but wanted something different and if memory serves me correct the Toyos are quieter than the AT3W even when I first got them but hard to say…)
I like the look of the tire (Not to aggressive but not too simple either…) and I really liked the weight. Published weight on the tire is 47lbs and I put one on my scale and it was 46.7lbs
I’ll update here as I put more miles on them. Love the look with my lift!!
Do you have any more thoughts now that you've had them a couple months?
I'm on 265 SL Wildpeak and am contemplating upsizing to 285s. I'd love to stick with the Falken's again as my current set has exceeded all my expectations, however the heavy weights has me second guessing myself. I'm looking to keep unsprung weight as light as possible.
Seems like the AT3s are among the lightest of the bunch, and perform well all around on and offroad. I do a lot of offroading around Colorado and Utah and am starting to get more into rock crawling so I'd probably be looking at 285 C load.
The vain part of me is also hesitant because the sidewall design is a huge step down from the Wildpeaks in terms of aggressiveness and I sure do love me some meaty sidewall....
Sent from my Pixel 4 XL using Tapatalk
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 09:04 AM #159
bzizzi's Avatar
bzizzi bzizzi is offline
bzizzi will become famous soon enough
bzizzi's Avatar
I install a set of TOYO OC AT3's on my 2020 TRD ORP with RRW wheels that are 1" wider than factory wheels, ordered wheels with zero offset. I really like these tires, handle great and not noisy at all. Look great and so far do great in the rain.The biggest surprise was no difference at all in fuel mileage compared to stock Dubmflop Tires, I actually think I picked up one whole mpg. I get a consistent 20/22 mpg on the highway burning 87 octane ethanol free gas. NO BS !!!
bzizzi is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 07:34 PM #160
Acefaaace Acefaaace is offline
Acefaaace is on a distinguished road
Love them. Have mine on 285/70/17 SL. Able to handle trails with ease.
Toyo Open County AT III (AT3)-cfa77de1-3fe8-4c1b-8450-6934e089f78d-jpg
Acefaaace is offline   Reply With QuoteReply With Quote
Old 11-07-2021, 07:28 PM #161
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Haven’t done much Offroad. Busy with other things... Where I have had it off road it has done well in mud and mild rocky trails. Still pretty quiet on road and they drive smooth. Hasn’t affected mileage as much as I though they would considering the difference in general power and acceleration and the need to downshift faster. Interstate trip had me at 18.5 mpg with avg speed of between 65 and 70. If I went with C or E load, I don’t think I would care for the lack of power due to the extra weight. I don’t really need the heavier loads with what I do and where I live.
I was also concerned with the lack of sidewall lugs going from my Wildpeaks. But I think the lift along with the larger size has mad it work. But I believe Wildpeaks in 285 would look really good… Just so heavy…
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 01:30 AM #162
toseeg toseeg is offline
toseeg will become famous soon enough
Replaced my KO2s with Toyos in 285. No regrets.
Toyo Open County AT III (AT3)-img_9582-jpg
2016 Trail, 285 Toyo AT3, OME
toseeg is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 09:25 AM #163
Plan B Plan B is offline
Plan B is on a distinguished road
Did you go with C load?
I’m between these, and KO2 in C load.
Plan B is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 12:57 AM #164
jcaplingr199 jcaplingr199 is offline
jcaplingr199 is on a distinguished road
In stock tire size 265/70/17 would you go falken wildpeak at3w or toyo OC at3?
jcaplingr199 is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 02:03 AM #165
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
I have experience driving with both on 5th gen 4Runners (family members). I'd go with the Toyo A/T3 without reservation. Toyo is just a better made tire.
02SE is offline   Reply With QuoteReply With Quote
at3 , county , put , toyo , toys
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Toyo Open Country H/T in 285/70/17 4RunnerAU 5th gen T4Rs 0 08-31-2016 07:36 AM
Toyo Open Country MT on 4th gen hobosapien 4th Gen T4Rs 9 05-06-2016 11:41 AM
