Exterior Side Accessory Panel NOW AVAILABLE!
Victory 4x4
Official Vendor
We have gotten lots of requests for this Exterior Side Accessory Panel. So here it is! Coming soon. It bolts to our roof rack and uses a vacuum suction cup to secure it to the window. Mount RotoPax, quick fist mounts, etc., tons of options! Who would be interested?
I like this! I have a 4th and 3rd gen though, no fancy roof-rack. But it gives me ideas on how to mount a rotopax on both the T4Rs
Any testing for fitment on an SSO rack? and I was wondering how secure the bottom is? Wouldn't want the suction cup to break loose, have the thing bouncing around and crack the window with the weight of a rotopax.
We have not tested on other racks, but I'm sure it could be made to work. The vacuum suction cup is extremely solid.
Regarding the vacuum suction cup. Is this one of the models that you physically "pump" the cup body to vacuum onto the glass? These are common in the glass industry for manually handling large sheets of glass and they are extremely effective even carrying glass sheets weighing several hundred pounds.
Yes exactly, there is a plunger pump on the suction cup.
Very cool, you'd probably get more interest if you could come up with an add on mount that would work with Gobi and Baja racks as well
Kind of looks like a broken window waiting to happen.
Here in AZ I've had terrible luck with suction cups holding things to the glass. Well, a few phone mounts anyways.
I really appreciate the effort that you guys put in to bring new products to market! This one just doesn't do it for me, but I will keep watching for the next one.
Should add more clearance along the top. That looks really close to the roofline.
Also, two suction cups on the side maybe? Just thinking about the panel flexing if there are heavier items on it. But I'm guessing that one is more than stable if the whole top section is mounted.
Awesome! Would love one that is compatible to the racks that dont have the flat side like yours. I have a gobi rack and would love to have this be compatible with that.
As Big Daddy K said about suction cups in Arizona--that could be a problem. Rubber parts and even silicone parts exposed to the heat and UV rays in Arizona do not hold up well. Even if the cup attaches strongly, it appears the weak link is the cup material hardening and cracking with exposure. Do you have any info on longevity of this part when exposed to high heat, UV rays?
I like it, I just need to order the roof rack first. Seems like an excellent solution to additional storage. Others are concerned about the UV and heat with the suction, I'd be interested to see how it performs in subzero and winter temps in Maine we don't have to worry about it being too hot too often.
I'll echo my concern over only 1 suction cup, 2 might be better, especially for those of us who live in extreme climates: like ND or AZ. Definitely interested in this. I have your console and rear molle panels and I'm extremely happy.
