ARB drawer system + Tilt of back seats work together??
whiskeydog
ARB doesn't even know surprisingly, just called them.
When you install the ARB drawer system in the cargo, do your rear passenger seats in your 2019 TRD PRO 4runner still tilt back?
I ask because I have a carseat that needs to have that extra tilt that helps.
Works fine. I have a car seat on the driver side. You may need to remove the angled piece behind the seat that has the drings on it. The ability to angle the seats depends on the installation. Intstall too far back and youll hit the trunk door. Too far forward and youll block the recline function.
Theres no "right" way to install these. They were made for a different car and happen to fit 4runners. The most flexible install is a plate system, but I (and others) drilled out the factory 2 bolts that have pot metal on them and then also used the crossmember with rivnuts and got a good result.
Sent from my SM-G973U using Tapatalk
THANK YOU for answering. I feel confident now in the money spent. Cheers.
