Old 10-29-2020, 05:02 PM #1
Johncmng Johncmng is offline
Johncmng is on a distinguished road
Upgraded from 265s to 275s. lost acceleration and mpg
Will swapping gear fix this? Can I get the acceleration and mpg back? I went from 18mpg to 15.5mpg. And what does swapping gears? Do I swap the gears in the gear box or swap gears in the rear AND front diffs?
Johncmng is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 05:23 PM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
What tire and size? 275/70 r17, 285/75 r17? LT or P? Brand and model?
How are you measuring/ calculating mpg?
Gear swap is fed and rear differentials.
Good luck
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 05:41 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Weight might be playing a factor too. What specific tires/size/load rating did you get?
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 05:48 PM #4
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Typical gear swaps means removing both front and rear axle differentials and changing the gear ratios so that a revolution of the drive shaft to each differential results in less rotation of the wheels.
The only gear ratios available are what you have now - 3.73. And then there exists 3.91 from the Lexus GX and then the gears available jumps to 4.56. 4.56 gears would match with 39" tires. You've gone from 31.6" tires to about 32.1" tires. It's unlikely that gearing for about 39" tires would help your mileage.
I would start by making sure your tire pressures are correct. With LT rated tires - you should be running around 40-45psi. That may help some. But also they are heavier and higher rolling resistance.
Old 10-29-2020, 06:50 PM #5
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I don't think gear swap is going to much good with switch to only 275s.
Part of the price to pay when going bigger.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 07:09 PM #6
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
I'm assuming this is going to be a stock road oriented tire (like the Dunlops) over to something much more aggressive and heavy (maybe C-rated Falken AT3Ws)?
Some of the MPG loss is almost certainly related to weight and tread pattern, not the tire size alone. Even if you swap from the stock OEM highway tires over to a more aggressive C or E load 265/70R17, you're probably going to see your MPG go down by around 1 at minimum.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 09:42 PM #7
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Nope. That's why new cars usually come with lame tires. Long wear, low rolling resistance.
delloro is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 10:13 PM #8
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
now you need a supercharger and a gearing change. the cycle continues.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 10:18 PM #9
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I run 285s and avg mid 17 mpg.
I have a 12 mile, 6% grade to go up and down to get to work.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 10:50 PM #10
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
I'm two weeks in going from 265 stock dunlops to 285 atIIIs, so far no real need to go for a gear swap just yet but I have almost zero added weight. I do want a super charger though..
NorthPark is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 10:56 PM #11
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
I’m running 285’s n my mileage is 17.4. I noticed a slight decrease in performance but for the price of a gear swap, it’s easy to ignore.
Muskrat14 is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 11:24 PM #12
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Get a Pedal Commander. Sprint Booster. HikeIt.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 11:27 PM #13
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
This right here ^^^
Gotta pay to play.
Re gearing is a costly upgrade. Be prepared to put out some coin.
I run 285/70/17 Falken Wildpeak MT’s. Heavy ass tires. I average 15mpg
16 on a good day.
mcat707 is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 11:35 PM #14
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
So you added 15lbs or so to each corner, and increased the surface area and rolling resistance, but you're surprised that the engine needs to burn more dino juice to do the same speed on the highway than it did before the new rubber?
Takes all sorts I suppose...
Re-gear will cost you about $3 - 4k in parts and labour
btw, the sun is bright. Don't stare at it too long....
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 11:37 PM #15
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
When I went from the factory 265's to 275 KO2's in a E load I lost about 1.5 to 2 miles per gallon. The E load 275 weighs a hefty 58 lbs. as I recall, and that is the major reason for the loss of acceleration and gas mileage. I went to 285/70-17 Falken AT3W's in a Standard Load (SL) with a weight of 51 lbs. each. My gas mileage improved by .5 to 1mpg over the 275's.
Acceleration seems to fine in all conditions with the 285's. I drive 5 miles to work by street and go through an elevation change of 1400 feet up and down. I consistently get 15-15.5 mpg doing this. I use to get 14.5-15mpg with the 275's. I would not waste money on a gear change. The 275's actually put the speedometer right on the money and the 285's are only 1mph off.
TRD PANTHER is offline   Reply With QuoteReply With Quote
acceleration , gears , mpg , swap , swapping
Upgraded PML Transmission pans? Worth the money? What about upgraded valve bodies? randy88fj62 4th Gen T4Rs 9 08-21-2020 04:53 PM
Lost acceleration while driving. boomtown757 Problems & Warranty Issues 2 06-23-2019 06:01 PM
Who’s running 275s? Fried_man7 5th gen T4Rs 22 12-01-2018 12:34 PM
Looking into Hankook 275s... PCH4R 5th gen T4Rs 1 10-30-2016 09:18 PM
goodyear MTRs 275s 4RunnerTrail 5th gen T4Rs 1 04-15-2012 05:20 PM
