11-24-2020, 08:14 AM
Real Name: Scott
Real Name: Scott
Need some battery advice...
Wife jumped in the T4R last evening at work, and it wouldn't start. Two or three attempts later, if finally starts for her. I poked around last night, battery was 12.37V sitting in the garage, and charging around 13.9 V when running. Let it sit all night in the garage and its 12.11V this morning an dropped to 9.7V when I started it.
Appears to me, that this battery is weak, and on its way out. I am disappointed with the longevity for a vehicle that is 2018 with only 61000kms. Definitely the shortest lived OEM battery I have every gotten in a vehicle. Now... is this because of all the extra electronics, screen, navigation, etc. found in today's vehicles or did I just get a bad one?
Advice I'm looking for, is what to replace it with? I see lots of posts about Northstar and Odessey Batteries, at a premium price, especially here in Canada. I was thinking of putting a Costco Battery in. I've had good luck in the past, and their warranty is great. My Costco also has the Optima batteries, but like the others mentioned, are they really worth the extra cost? Maybe, if all the electronics are the potential cause.
I know everyone has a differing opinions on batteries, just curious what has worked for you. I just need something reliable that will make it start! Suggestions and opinions welcomed. I threw my jumpstarter in, and get to drive it for a couple days to see it is replicates her issue, before I just yank the battery out and try that. I just got to work and its gonna sit out in the yard at -5 Celcius for the next 9 hours... will be curious to see what is reads for voltage this evening.
2018 T4R SR5 Premium - Classic Silver Metallic
11-24-2020, 09:14 AM
OEM battery lasted me about 3 years. I then used a walmart battery by force. They were the only place opened at midnight. It lasted about 4 years. I then put in a battery from Autozone which is doing fine. I think all the mainstream are about the same life. Plan on every 3-54 years depending on your accessories of course.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
11-24-2020, 09:30 AM
4 years life on a battery. Then just get a new one.
the marine batteries on my three F225 Yamahas lasted exactly 4 years and then you get new ones. Replacements were Done this at least there times. https://www.linkedin.com/in/mrs-lind...ara-78a1b6136/
11-24-2020, 10:01 AM
Truth is most batteries all from the same place
Source: We haul batteries/cores
Its the warranty you're buying. I haven't the need for an Odyssey yet and anything I've bought so far for my vehicles has worked out pretty good for at least 4yrs.
I live in a warm climate though. Also, what happened in the last 5 years where batteries are hitting over $150??
00-JZX100
10-Trail Ed.
11-24-2020, 10:02 AM
Real Name: Sparky
Real Name: Sparky
Batteries last longest in moderate cold areas, once you get into the extreme cold, though, the cold snaps start to kill them off again. The shortest life expectancy would be in the deep South.
Old and (c)rusty.
generally the comments about the stock panasonic battery are very positive, most people get really long life from them and are disappointed that they can't buy them as replacements in the US
11-24-2020, 10:21 AM
Also, a little routine terminal maintenance and cleaning/spraying/tightening will go a long way to help preserve the battery. Bad connections will kill a battery.
Especially with the crappy terminal clamps that are on modern vehicles.
I replaced a corroded clamp on my wifes camry with a marine battery clamp. They are solid like the old style and so much beefier.
I am fragile.
Not like a flower.
But like a bomb.
11-24-2020, 11:08 AM
I bought a used 2018 4runner and they had oem battery installed in 4/20 and it was already out. The car had not been started for a while. Good battery maintenance and using the battery regularly is a very key factor to battery life.
11-24-2020, 12:31 PM
Damn I hope mine lasts 54 years
For OP - I just replaced the stock battery in my 2013 trail with an interstate from Costco. I did not need a bigger battery yet since I do not have a lot of accessories. Like a lot of people already said, most batteries seem to only last 4-5 years.
I can not believe my stock battery lasted more than 6 years. No signs of dying either but thought I would replace just in case. Would probably never go with a battery for that long again.
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
11-24-2020, 12:39 PM
Real Name: Sparky
Real Name: Sparky
My car batteries routinely lasted 5-7 years in CO and WY.
I barely got 3 years when I lived in central FL.
Old and (c)rusty.
11-24-2020, 12:52 PM
Still on my original battery, but I would go for the cheaper between the costco battery or the duracell from batteries+bulbs, if you have that store over there
2014 Trail || Grabber AT2s
11-24-2020, 01:23 PM
.. and OEM alternator voltage vs AGM battery. No happy middle ground.
11-24-2020, 01:45 PM
Never occurred to me before that location (I am assuming weather/temperature is the root cause?) might be a factor in battery life lol. Learn something new every day. I am in MN and always seem to get 4-5 years.
11-24-2020, 01:53 PM
My vote is for Costco Interstate. Great price and no questions asked replacement within first 2 years.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
