Old 05-03-2021, 10:28 PM #1
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
275/70/17 vs stock 265/70/17
Hello,
I reviewed the sticky:Going Bigger - 5th Gen Tire Fitment Guide and would like some guidance. As a beginner 4x4 enthusiast I don't want to go any tire size larger that requires a lift or any other mods. I also don't want to raise the center of gravity so my option is to stay with the stock 265/70/17 size. But I noticed you can get a 275/70/17 which is in the chart as a "no rub" choice. I don't mind the -1.7 speed diff so this seems like a no brainer to me. Is there anything I should consider that I might be missing with this choice? I plan on getting BFG K02's. Of course I'm assuming the 275 gives slightly more grip than a 265. I don't plan on doing any crazy rock climbing, just dirt roads but some may be a little hilly etc.
Thanks
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:34 PM #2
strictlys strictlys is offline
strictlys is on a distinguished road
It seems like you made your mind. The 2757017 just doesn't have too many options in tires compare to 265-70-17. Also, your spare is a 265-70-17.
strictlys is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:38 PM #3
Also, I forgot to note that most 275-70-17 comes in an E load range. Weight and stiffness would bother me. My 4runner is my wife's ride, but I have a 16 Tacoma. I use to have General X3 Mudders 265-70-17 in an E load. Wow... the car was so stiff and heavy. I now have 285-70-17 ATKO 2 in a C load range and it was significantly lighter as well. It drives much better.
Things to consider.
Old 05-03-2021, 11:43 PM #4
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Originally Posted by fourrunnerbill View Post
Hello,
Thanks
275 vs 265 may or may not yield more 'grip' depending upon the terrain and traction available.
TIRES. FAT OR SKINNY for Overland Touring? AndrewSPW Land Cruiser build-7 - YouTube
Regardless, it's going to be almost immeasurable. It will raise the vehicle CG slightly, but again it will be very small. Same with gas mileage. Once you take into account that your odometer is under reporting by the same amount, and if you reduce your speed to match, you won't see a measurable difference in mileage/range due to the tire size change you're looking at. Tread pattern, weight of the tire, P vs LT, tire pressure etc. will play a much larger roll in off road and on road manners and mileage.
A larger diameter tire may smooth the ride out over bumpy terrain, but we're talking small values here. A skinny tire will comply (deform) more readily at the same tire pressures to yield more grip... the answer to your question is do whatever makes you happy.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:53 PM #5
Thanks for the great input. Going with stock size it is...
Old 05-04-2021, 01:35 AM #6
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
I have the 275 BFG KO2's on my rig with no other mods. They do perform well for all of my wheeling; however, I will be going to 255/75r17 when I change them. Same height as the 275, less weight, and load range C. I did notice the weight and stiffness with the 275's. It's not bad enough to make me swap now but, after 9k miles, I've decided I don't want E rated tires next time.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 02:41 AM #7
Gouranga Gouranga is offline
Gouranga is on a distinguished road
Hello,
Thanks
just so you know the k02s in 275s only come in E which is heavy AF 55lb
vs 39lb from stock tires this is 16lb......
Gouranga is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 11:12 AM #8
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
This is a sound decision. I moved up to 275's when the Cooper AT3's were available in a LTC in that size. I loved those tires (too bad they don't make the current Cooper AT3 XLT in that size anymore), but unless you are heavily off-roading its better to save the weight and get a good 265 all-terrain in P-Metric/SL. "C" load would be the heaviest I would go unless you really need it. FWIW my SL (standard load) 265 Falken Wildpeaks held up for a week out in Moab and I've been happy with them.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 11:48 AM #9
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Good choice. It's quite likely that whatever A/T you go with will already look a lot beefier than the stock tires even in the same size.
For example, here's my rig with stock tires:
And here's my rig with stock size (P265/70-17) Falken Wildpeaks. These are a LOT more "square" at the edges of the tire so look a lot wider/chunkier than the stockers:
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 11:59 AM #10
dew299 dew299 is offline
dew299 is on a distinguished road
Here's K02s in 265. Hasn't been too long, but I like how they have performed so far.
Sent from my SM-G970U using Tapatalk
dew299 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 04:42 PM #11
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Stock size KO2s look 1000% better than the original HT's, are taller, and will get you anywhere the E load/really heavy 275s will. Really no point in the 275s, IMO. I went with the 265s and love them. Aside from a minimal MPG hit, they are amazing. Love them so far.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 05:38 PM #12
jesus the 265's falkens are 53lb... you may as well get the 275s KO2s same weight at the 265s
but the real question how noticeable was the acceleration loss as 39lb vs 53lb is a 14lb difference for same size tire
Old 05-04-2021, 05:43 PM #13
The P265/70-17 I have are 46lbs (and some people think that's higher than they actually weigh). The E Load LT265/70-17 are 53lbs.
I noticed a slight decrease in "peppyness" and maybe ~1mpg drop in fuel economy, but nothing earth shaking. If I didn't know the tires had been changed I probably wouldn't have even noticed any difference. And I'm pretty anal about vehicle "feel".
Frankly the KO2s weren't even strongly considered. I've had them before and didn't find they did very well in the rain as they aged, and I've read enough other similar thoughts on them that I was looking for something different.
1998 BMW M3/4/5
Old 05-04-2021, 05:53 PM #14
how are the k02 taller? its 31.6" while the stock duller tires dueler are 31.7''
Old 05-04-2021, 05:58 PM #15
oh sorry didnt realize you got em in SL ..... only a lil heavier than the k02s in C in 265 44lb vs your 46lb... fair match
but you still goofed because the SL in 46 only have 14/32 of tread depth while the E has 18/32
275/70/17 , choice , plan , size , stock
Spidertrax 1.25" - Stock 2000 Suspension - 265/75/16 on stock 5 stars... SlickmisterN 3rd gen T4Rs 3 01-24-2015 05:38 PM
Caster question for stock supension and stock size tires... FrontRange4Runner 5th gen T4Rs 5 03-27-2014 02:53 PM
F/S CA Stock Catback 2001 Sport V6 4Runner & Stock Rear Springs & straightpipecatless GoHideTheAsian Classifieds - buy & sell (no commercial ads please) 4 02-06-2011 01:04 AM
Very nice Headrest Monitors, 06 JBL 6 disk, stock speakers, stock sub whoosh Classifieds - buy & sell (no commercial ads please) 2 07-30-2009 12:39 PM
