SCS Ray10 -38 offset
I have 2.75 front and 2 in rear and no way I could have fit 285/70s + -38 offset and driven without BMC. I had 285/70s on a much smaller rim and it was almost touching the BM.
Ah, good to know.
And when you say “smaller” I assume you mean narrower/ more conservative offset rim?
Thanks for the feedback btw.
yes, you could have. essentially an -38 is like a -6 w/ spidertrax spacers. ran that setup w/ 285/ 70/17s for 3 or so months. would not recommend it off road and you'll rub in reverse when turning, but it will float you on road if you're between paychecks. granted, I'm 3" up front, but I'm sure its doable if you baby it.
Anyone put on their wheels BEFORE getting a BMC?
I’m getting wheels and tires (285/70) this week and a BMC a few weeks after. I’m curious if I can survive driving it around.
I have 2.75 front, 1 in rear and JBA’s.
yes you can, you will rub in reverse and at full wheel lock on the body mount. IT will be LOUD.
IS it livable: yes
Is it super annoying: yes
Will everyone think your vehicle is broken every time you back up or turn a sharp corner: yes
Will you destroy your mudflaps: yes
Is it super embarrassing: yes
I ended up getting a BMC soon after and I have never regretted it.
Have any of you had issues with Ray 10 hubcaps falling off? I've had mine for about 2 years and lost 2 hubcaps. The first was missing after driving a lot of rough washboard dirt roads. I assumed that was the cause. It took 3 months to get a replacement because of low stock. About a week after getting the replacement, another one was missing. This time I had only driven it a few times and only on the street. I don't know if the hubcaps are crap and easily fall off or if someone is stealing them.
Ah, good to know.
Yeah, I had a 17x8.5 with a 0 offset on 285/70 and had no rub except turning over bumps. Sounds like a couple others did it with -38mm but I def had less than 1" with my wheel turned between the tire and BM.
IS it livable: yes
Ha! I had secondhand embarrassment reading this. Thanks for the the mental preparation. I’ll blast Spice Girls with my windows down.
BMC is definitely happening. I was just hoping the truck is drive-able as the chop is 2-3 weeks out; wanted to make sure the shop can assess the clearance of the entire front well.
Not specifically with Ray 10s but i lost two on my SR8s. My original hubcaps were only a snap fit, but when i ordered several scratch and dent replacements, they had snap rings on the inside. I just came back from a long off road/camping trip and they are still attached.
I haven't had any issues with my Ray10s chipping or fading in color. However, these are the stealth blue ones and maybe the coating is thicker? Who knows..it looks like paint though as opposed to powdercoat.
Finally finished my BMC but still undecided with new tires 285 or 295 on 9” rim
If I only knew about its quality I would go with ICON. That was my second option.
Anybody wants to buy my rims? Just kidding.
If only Icon offered something more aggressive than a 0 offset. At least a -12. With that said, I love the look of my -38 SCS BR6’s - no issues so far.
