08-01-2021, 11:28 PM
Phone mount options?
Looking for a solution for a solid phone mount instead of using my cup holder. Anyone have a good one? I have a pop socket in the back of my iPhone X but I think I can squeeze a magnet on the back for magnetic mounts. I don’t want a mount covering my vents for sure.
2016 White Trail | Black TRD Pro wheels | Victory Off Road Full rack | Ironman 4x4 Nitro lift kit with UCA | BFG AT 285/70/17 33
2001 Silver SR5 Sport | R.I.P. 244k miles
08-01-2021, 11:33 PM
I have used ProClip for years on all my cars. I love them and wouldn't have anything else. ProClip USA | Car Phone Holders and Dashboard Phone Mounts
Yes, they do go in front of the A/C vent for the 4Runner, but that is actually a good thing for it keeps the cell phone from over heating in the sun.
The beauty of the ProClip is it comes in two parts: one that is custom fit to the vehicle, and the second is custom fit to your cell phone. Also, they are no drill clip on installation and very sturdy.
08-02-2021, 12:43 PM
Originally Posted by 4wheeldrivesmatter
I use this (^^^^) one in my Jeep and love it! The only problem I had with it in the Jeep and the 4Runner is eventually the adhesive gives way. I eventually just bolted it to the dash in the Jeep since the size and placement is perfect for me.
However, in the 4Runner I couldn't find a good mounting point where it was within a finger distance with my hand still on the wheel. I eventually swapped for a 67 Designs set-up which I... somewhat like. If you end up that route, don't by the Gen 2 magnetic mount. It has no magentic power and your phone will just slide off. I just ordered a Gen 3 magnetic mount from them and am hoping that works as good as the cheap mount from Amazon since I already have the new 67 Designs base bolted to the dash.
2015 4Runner SR5 4x4, Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
08-02-2021, 02:53 PM
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
08-02-2021, 07:02 PM
Originally Posted by AggieOE
I use this (^^^^) The only problem I had with it in the Jeep and the 4Runner is eventually the adhesive gives way. I eventually just bolted it to the dash in the Jeep since the size and placement is perfect for me.
The ProClip, mentioned earlier, has no adhesive, no bolts, no drilling or other modifications. I have never had one come off or loose.
08-02-2021, 08:05 PM
Real Name: Dave
Real Name: Dave
Shirt pocket.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
08-02-2021, 08:55 PM
[img]mg]
Can you update with how the 67 Designs Gen 3 performs? I've wanted to bolt in a 67 Mag mount but was turned off by the lack of "stick" reported by users... that's a no-go with my off-road use. If the Gen 3 sticks better, i'm ordering one.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
08-02-2021, 08:59 PM
I was using the Scosche mag mount until the adhesive died during this hot ass summer we're having. During the winter it worked fantastic and the mag plate attached to my iphone 12 case wasn't really noticeable. The second it turned hot, the adhesive bit the dust and now i'm debating on drilling in a mount system. Before that I was using a RAM Mount bolted in to the dash (head unit). Works well but I get tired of the arms and where they hit on the phone side buttons. 67 Designs will likely be my next mount.
08-02-2021, 11:21 PM
Phone holder
I've been using a Lisen magnetic phone holder that I bought on Amazon for about 10 bucks. It does attach to the vent, but it sits away from the vent a couple of inches closer to me. I've had it a couple of months an so far, it has worked out great. Enough magnetic power to hold the phone while bouncing around off road, but not too much holding power to stress the vent. I keep the metal plate under a thin case on my iPhone.
2020 TRD ORP with KDSS. 285/70 17 BFG KO2s. Bilstein 5100s w/ stock springs on top perch in front, and Bilstein lift springs in rear. SPC UCAs. RCI rock sliders. C4 Fab Low Profile front bumper with Smittybilt H20 12k winch. Factor 55 Flatlink E. RCI roof rack, Baja Designs and cheap Amazon led lights, Switchpro 9100, BeyondWraps hood scoop stamp.
08-03-2021, 02:52 PM
Yeah absolutely. Just came in last night. Works great! WAY better than the G3. Magent power is about on par with the cheap $7 one from Amazon although much better mounting positions. Note that it is BIG though and takes up almost the entire back of an iPhone7. I have one of those 'LoveHandle' elastic things mounted on the far side of the back of my phone with the steel plate across the rest and it works sufficiently enough and overhangs the mount just a bit. If offroading shows this method not working, I'll just remove the elastic strap and let the whole phone contact the magnet. I know that'll work if this current set-up doesn't.
Looking back, I'd have done the diamond plate base, nano arm, and G3 magnet. No way I'd order a G2 for anything unless it was going to be used primarily horizontal.
08-03-2021, 02:56 PM
I use a pro clip with the wireless charger. Been working great for a long time.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
08-03-2021, 10:35 PM
Here is a thread previously started in regards to the same subject, it may be of some help.......
2019 Current phone mount solutions?
Best Regards,
Saker
08-04-2021, 03:35 AM
I'm using a two-part setup. A belt and suspenders solution. Engineer style.
I bolt a RAM Mounts X-Grip to an ICS FAB Dash Mount platform. The ICS mount lets me secure items to it (HAM, CB, radar detector, tablet) when I need them. However, I can add, relocate or remove them as required. All without drilling new holes in my dash.
-SK
"Sometimes I sit and think. Sometimes I just sit."
08-04-2021, 11:52 AM
ram mount and ics center console
