Rear Window Disable/Lock
DingleTower
The other day, while driving down a gravel road, my dog put his foot on the rear window button causing the thing to auto-roll all the way down and sucking an ungodly amount of limestone dust into the cabin.
Any way to disable or lock this button separately from all the others? I rarely use it but I don't want to just disconnect the button either.
Not sure if it was changed on newer models, but try to use Windows Lock switch. I used it to prevent kids to open rear passenger windows and found out that I can't open rear window after switch is activated.
That will do it but I didn't want to lock all windows.
Put a small hinged cover over it? Or relocate the switch.
Probably shouldn't allow pets up front.
A cover was what I was thinking but I want something that looks clean.
Dogs ride in the back. Just happened to go over the barrier (which never happens) and the first spot his foot ends up is right on that damn button.
Luckily the switch is flush so a cover should be relatively easily made.
That's definitely a spot pets will step on.
