TRD Pro Rims - are all colors the same rims?
RobS10
Are the Gun Metal, Gold, and Mat Black TRD Pro rims the same actual wheels with the same width/offset, just different colors? Price diffs are significant
Yes they are. All 17x7, +4 offset.
Thank you. Am looking at the Gun Metal as they look like the ones least likely to show scratches and get dirt embedded in the finish like I would imagine would happen to the black ones over time. Plus, they're the cheapest :D.
I just paid $172 a wheel from Olathe Toyota in Kansas City for matte black. Should arrive tomorrow. Shipping was around $100.
I picked up a set of TRD black wheels years ago during a trd pro sale at $119 per wheel and was able to sell SR5 OEM at about $400
You better double check the OEM part #'s on the gunmetal color. I believe they made these in a flat & a gloss.
I just picked up the gloss gunmetal. I had the black ones for years and wanted a different look, and hoping the wheels stay cleaner due to the glossy finish.
Besides the price, that was a big reason I was looking at the gun metal too.
Rob- Just to be clear - there 2 gray TRD OEM rims which are similar to what you're looking for.
From what I've seen, the cheaper of the 2 - are the matte gray (original) with the red letter center caps. PTR20-35110-GR
The Gun metal, Gloss, are slightly more expensive from what I've seen, and have the black TRD letter center cap. PTR20-35110-G4
These seem darker as I've said but really pop when its sunny out as the finish is more mettalic than the matte gray. They have a clear gloss coating.
Just wanted to make sure you got the ones you wanted!
Thanks Brian! I didn't realize there was two versions, will definitely make sure to look at the gloss ones as nothing worse for holding mud and brake dust over the years than a matt finish. The OEM aluminum wheels on our '99 4R look nasty on the inside edges of the "spoke" where the casting texture is like sand blasted metal.
A side note: The official Toyota website is like Cybil these days! One day, you can add all kinds of packages. The next, hardly anything. The next, you get all the options back again!
