Old 07-18-2022, 07:37 AM #16
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
For some it's a structural thing. I can't remember what thread I saw it in but the BM will supposedly help to keep the fire wall and floor pan from getting crushed in a head on collision.
The DRT relocation kit claims to be the strongest, and certainly looks good for those that care about aesthetics. It is the most expensive I believe.
I have no experience with it, but there is a fab guy Timbo's Customs in Florida who is on Tacoma World, and has installed several of them. Maybe he can shed some light on the quality and install.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-18-2022, 09:45 AM #17
if i was going to do it right, i'd do the DRT one. most guys who do the chop and fill dont have the ability to do the DRT one though cause....4runner owners......
Old 07-18-2022, 09:49 AM #18
Jeremy556's Avatar
Jeremy556's Avatar
It's to keep the front wheel from intruding into the cab in the small frontal overlap crash test. I figure my plate bumper will turn the 4runner sideways and into a nice high speed rollover in that scenario
Old 07-18-2022, 01:16 PM #19
Real Name: Brett
Real Name: Brett
I've been making a horrible attempt at some fab work on my 4th gen LT project. Major trial and error.
So I can attest, my welding and fab skills pretty much fall into said category. Luckily my 23 yr old neighbor has a tig cert and works out at the space center.
Needless to say he saved my ass when he took over mig duties on my Runner. I tack it, he glues it.
Old 07-18-2022, 06:05 PM #20
sounds awesome actually.
Old 08-02-2022, 11:40 AM #21
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
After all the front end work has settled in, there is still some slight rubbing on the right side.
Both sides were rubbing the "body mount bump" on the mud flaps. Removed those and the left side clears.
Time to get the angle grinder to remove and smooth the shiny spot.
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 05-07-2023, 07:57 PM #22
bayaz bayaz is offline
bayaz will become famous soon enough
No, they are not created equal. I haven’t encountered any that are the same thickness as the Toyota frame - usually the plates are too thick, which makes it a PITA to weld on, as you need higher temp to weld thicker steel.
bayaz is offline   Reply With QuoteReply With Quote
body , job , mount , plates , sm-s908u
13 LTD Body Mount Chop ? Shogun 5th gen T4Rs 1 02-19-2018 07:51 PM
Metal tech body mount chop plates gtg? LandCruiser 5th gen T4Rs 3 06-06-2016 06:22 PM
Body Mount Chop? Veet Skeet 5th gen T4Rs 18 04-04-2015 09:35 PM
Body mount question ( not a body mount chop) crashman 4th Gen T4Rs 1 09-30-2014 01:57 AM
Body Mount Chop? 01grander 4th Gen T4Rs 8 04-01-2013 01:01 AM
