How to tap into dome light
emmantik
Hi all,
Just thought I'd share how I figured how to tap to the dome light since there is no other post about it. This is for wanting to have accessory lights to turn on and off with the dome light. For me, I added footwell lights to my 3rd row as there is no lighting back there for the kiddoes.
First off, I fished a wire from the rear right passenger headliner. The overhead grab handle would need to be removed first. I ran the wire down the B pillar and down under the footwell trim to the rear wheel well.
To remove the housing you can read about it in this thread;
Remove Dome Light Housing
Once you remove the housing there is a small block that houses the electrical. You can pry up at 4 corners with a small screwdriver to release.
Once off, there is a metal housing/cover that simply pops off - just pry up. I left it off after as I needed the extra space for wires/terminals.
You can see with the red and black wires shown which side will give you power and which is ground. You will have to use your creativity here on how you tap/connect to these points - I will leave that up to you.
So far it works like a charm! The lights I installed even dim with the dome light!
Hope this helps anyone looking to do something similar!
I added a strip light to the upper part of the wheel well pocket. As you can see, there is an angled portion that gives the perfect direction to aim the light. Here is a shot of the end result.
I ended up doing both sides. I might change the strip lights (6" VLEDS) to Oznium 11mm LED flush mount bolts as I don't like seeing the light source - but the lumen output is great! LED bolts won't be as bright but I like the fact that I won't see them - just the light output. We'll see!
Decided to change the LED strips for LED bolts. Bit more discreet and not super bright just enough for what I need it for.
utkrstam
