Old 01-25-2024, 05:03 AM #1
BlueRunner428 BlueRunner428 is offline
BlueRunner428 is on a distinguished road
Can Portable Jump Starter Be Used for Push Button Start?
So my 4Runner is push button start and from what I understand, you absolutely should NEVER try jumping another vehicle if yours is a push button start nor I believe getting a jump if yours is a push button start (not totally sure on the latter). The reason is because you run the risk of frying the electronics to the starter system or something. My question though is, can a portable jump starter pack be used on a push button start, or are those only safe to use on key turn ignitions?
BlueRunner428 is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 05:44 AM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I have a 2012 Limited w push button and I've never heard that one. Maybe the newer models have changed.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 10:15 AM #3
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
The risk is present on any vehicle regardless of ignition switch type. The culprit being the human factor and incorrectly utilizing jumper cables, connecting them wrong or incorrectly in sequence etc.
These NOCO Lithium units eliminate that problem because they sense polarity. So maybe best to have one of those, small and portable. Safest bet I think.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 11:14 AM #4
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
Sounds like urban legend to me. I’ve had several push button start vehicles and never an issue. Hook up cables correctly and you’re fine.
hoppyjr is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 01:06 PM #5
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
You are fine to use a jump starter if you hook it directly to the battery.
Where the issue of frying the electronics, comes mostly from hybrid vehicles. Lets take my Toyota RAV4 hybrid as an example. The 12 volt battery is in the back cargo area and hard to get to (especially if the battery is dead and you can't unlock the rear hatch). To jump start it, Toyota provides a jump start terminal in the engine compartment in one of the fuse boxes. You hook up the positive cable of your jump starter to that terminal, and the negative a place on the engine block. The problem is some people have been attaching the negative terminal to a ground point next to the fuse box that just happens to be the ground point for the engine/hybrid system ECU. The high current from the jump start then goes through the ECU and fries it. Toyota released a T-TT (Toyota tech tip) to address the issue reinforcing the rule to attach the negative cable only to the engine and not near the ECU.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 03:20 PM #6
Whippersnapper02's Avatar
You can jump them like any other vehicle.
Old 01-25-2024, 09:04 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Seems like the owners manual would cover this.
Old 02-22-2024, 04:03 PM #8
dexter80 dexter80 is offline
dexter80 is on a distinguished road
Can confirm. We’ve jumped our ‘12 Limited several times with NOCO. No issues.
2012 4Runner Limited 4WD
dexter80 is offline   Reply With QuoteReply With Quote
Old 02-22-2024, 06:36 PM #9
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Not sure why you would settle for rumors and misinformation when this is covered directly and incorruptibly in the manual. Page 510 of mine. Ch.7. It’s available online if you don’t have a paper copy.
You can jump start regardless if key or push button. There are some specific instructions regarding smart key/push button procedure.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 02-23-2024, 02:19 AM #10
oliviabrandon361 oliviabrandon361 is offline
Real Name: Olivia Brandon
oliviabrandon361 is on a distinguished road
oliviabrandon361 is offline   Reply With QuoteReply With Quote
Old 02-24-2024, 11:47 AM #11
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
I think myths like this originate from people who have tried to jump start vehicles improperly and caused damage to their electrical systems. I've seen many people hook up jumper cables in very dangerous ways, including backwards and in the wrong order.
Using a jump pack limits that danger as it removes the 2nd vehicle completely and simplifies the process.
With jump pack off and vehicle ignition off, hook red to red, black to black. Power on the jump pack, wait until it signals it's ready to provide the boost, then start the vehicle. Turn OFF the jump pack, then disconnect black, then red clamps, although with the jump pack turned off, the last step isn't as critical.
When using booster cables:
Red to dead battery first, then red to support vehicle.
Black to support vehicle first, then black to dead battery.
Then start the support vehicle and then start the dead vehicle.
Remove in reverse steps.
I see a lot of people hook up both cables to the support vehicle while it's running, then hook up the cables to the dead battery, causing sparks, which can damage the electrical circuits of the dead vehicle.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
button , jump , push , start , starter
Portable Jump Starter Review - Audew On Point 5th gen T4Rs 0 06-23-2020 11:13 AM
Portable jump starter 5Sport General Discussions 40 07-26-2018 05:54 PM
Portable power, Jump starter, compressor Brookey_813 Accessories 4 04-27-2017 05:58 PM
Push Button Starter jpalaska 4th Gen T4Rs 31 04-15-2011 10:17 AM
Porta-Jump Portable Jump start JP4RNR 4th Gen T4Rs 1 08-10-2007 12:08 AM
