08-03-2023, 09:21 PM
#16
Real Name: Brett
Real Name: Brett
Originally Posted by Fareastplaza
Chrisridebike8, thanks for your suggestion. I should check facebook first. But it is already too late as I have already pull the trigger got a set of new Bilstein 4600. Sorry I might a little disappoint you guys here as I get boring 4600 instead of 5100. As a family guy, I don't really do off-road :-). But anyway, I watched a lot of videos and I think this is a task I can DIY. Will post some progress I really go DIY.
@ Fareastplaza
to tag someone to where they get a notify, you put the @ in front of the exact, case sensitive spelling.
Eibach has kits that are of good quality, but maybe not for the budget minded. Good Luck!
Eibach 2010-2023 Toyota 4Runner 4WD Products
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
08-03-2023, 10:07 PM
#17
Originally Posted by 4RunnerAquasport
This kit shows 4 springs with the kit, but states only two fronts. What rear spring would compliment this system?
Yep, I drive a 2019 Limited Nightshade...
08-04-2023, 12:31 AM
#18
Originally Posted by YelloLab
I just installed 5100 on my ORP. I love them and feel it's one of the best upgrades for the truck. I only drive on the road and never go off road. I set the front at .85 and still gives it the perfect amount of rake. I wish I put them on when I first got the truck along with the Michelin LTX tires.... Perfect setup!
This kit?
Bilstein 5100 Adjustable Strut & Shocks for 10-22 4Runner 0-2.5" lift
1996 Limited - OME 881/906 w/comfort shox | Deckplate | Hayden 1678 | 265/75R16 Revos | Koyo A1998 bypassed | Husky liners | Optima R34 Red Top | '99 Cupholders | Rear diff breather mod | (Totaled)
2012 Limited - Husky liners | OPOR sliders | 30% Ceramic Huper Optik | AVS seamless | Odyssey 34R-1500T
08-04-2023, 05:08 PM
#19
Bilstein 4600 vs 5100 Series, What are the Major Differences?
Give this a quick read. 5100 is only recommended for lifted and/or heavier than stock truck (big tires or body/interior added weight mods like winch, steel bumpers, etc..). It has firmer valving.
4600 seems to be a better match based on your use case. Aka: Stock
08-05-2023, 03:29 AM
#20
I love my Bilstein 4600s for stock height! Have them on front and back and it drives better than OEM. Just an FYI the OEM shocks and struts are fairly cheap for an OEM product.
08-06-2023, 08:09 AM
#21
Real Name: Brett
Real Name: Brett
Depends on what purpose you have in mind. Towing or carrying a heavy load but don't need a lift? Increase your spring rate to match the weight. Want a little bit of lift while putting a heavy load on it? They make lift springs with an increased load rating.
Want more suspension travel? Metal Tech makes a dual rate spring for longer travel suspensions that come in medium or heavy duty loads that give you a little bit of lift also. I have the MT mediums and love em. There are quite a few options out there.
Eibach has them on their site.
16+ 4RUNNER 1" REAR LIFTS SPRING
08-06-2023, 11:21 AM
#22
just change the rears first.. no alignment needed and you'll be done in 30 minutes each side
08-07-2023, 05:53 PM
#23
Front right on my '15 Limited with 68k miles is soaked, looks like i'll be putting 5100's on soon. $460 before tax/shipping for all four right now through Rock Auto. Was debating new springs but with less than 70k miles on the stock ones I don't think it's worth another $2-300. Also with the strut mounts for the top up front, ok to reuse the old ones or should i throw two of those in the cart before i checkout?
08-07-2023, 06:08 PM
#24
Unless you want different springs, replacing would be a total waste. Those springs have at least another decade and 100k+ miles of healthy life.
I would replace all rubber components and any corroded or damaged fasteners while I was in there.
08-08-2023, 02:10 PM
#25
I finally replaced 4 struts with Bilstein 4600 for my 2010 limited and removed entire X-REAS. As my truck is older and kind of rusty, plus it is the first time for me, it took me 2 full days to get the job done. First side was taking longer for sure as you will face challenges. When move to another side, you are master of this already and will be a lot quicker.
Here are some tips I would like to share, and they are based on 5gen 4Runner Limited with X-REAS:
- For front strut, not just doable without spring compressor, it is actually much EASIER and SAFER. So, I highly recommend you go this way. It looks complicated mentally only. Turns out it is the best and easiest way to do so if you do this work at home when car is stay on the ground with only 1 corner up.
- It doesn’t mess up my alignment at all, not sure if I am just lucky or because rusty welded it ��
- You only need one jack stand (to keep one corner up) and one jack to get all 4 struts replaced. It is safe enough, no hard force you need to do.
- To remove the entire X-REAS (I guess everyone will do this if you are reading my comments here), you don’t need to lift the entire car. You only need to do one corner at once, while you are replacing each strut. Of course, if you have X-REAS, you have to replace all 4 struts (I mean still one corner at once).
- Because of X-REAS, Oil will leak, but not too much. You will get messy, cannot really keep ground oil free. I put lots of cardboards and oil pan, but still oil dripped to the floor as sometimes you just cannot keep up.
- Do rear struts first as it is easier so you can gain some kind experience.
- As the job is oily, you will easily get brake rotor dirty. Make sure clean it up before you put tires back.
- To do front struts, you need a second hand to help you when you drop/lift the lower control arm. My 10 year old helped me. I promote to pay him double of the lawn mowing ��
- Neither front nor rear strut removal requires disconnect swing arm (Stabiliser Bar) at all. I didn’t do it and still can easily take struts out or put them back in.
The videos I used are following 3 which are good enough for everything:
08-08-2023, 04:22 PM
#26
Thank you for sharing your experience, lessons learned, and the resources you used.
I have a Limited and will likely have to do this one day, please share your thoughts on the 4600 vs XREAS (if you remember how it rode before failure)?
08-08-2023, 04:49 PM
#27
Saw a few videos on Youtube of guys ditching the Xtreas with Tacoma parts.
08-09-2023, 11:40 AM
#28
I didn't get chance to drive it yet. I will have entry here for sure after.
Another thought, due to huge price difference between 4600 and XREAS, both parts and labor, there is just no reason to keep it. I for sure won't go for XREAS shock parts and DIY at home.
It will be (4600+freeDIY) vs (XREAS+dealer's labor).
08-09-2023, 12:56 PM
#29
Also, instead of completely ripping our XREAS system. Maybe put a cap on the lines going into the shocks. And zip tie the lines out of the way? Its not difficult to take everything out, just a bit time consuming. Just a thought.
Yes, it is an option for some people. But I will not do this as the line is still have oil and pressure in it, not high/danger, but to some people like me, I really want a clean/sharp result without 'possible leakage' stay there. Just my 2 cents
08-09-2023, 01:00 PM
#30
I attached 2 pictures here so when anyone do it can find official torques.
Front:
Rear:
