275/55 20s...how do they fit?
Capt Goldtop
I've seen numerous posts regarding wheel and tire size, but I'm still not sure about the fit for 275 / 55 / 20s. I have a Limited 4x4 with the stock 20s and 245s, but I'm personally not comfortable overloading the rim with a wider tire. I'll likely either keep it stock or go for a 20" x 9" rim.
Will a 275 / 55 / 20 on a 9" rim be a straight bolt on? Or will I get rubbing, etc. Just wondering how tricky such a change would be.
Thanks,
CG
Sounds Like the Bro Show to me........
I don't Get it. More Sidewall Please, It's a 4x4 for Goodness Sakes, not a Crossover Unibody.
Thanks,
CG
275/55/20 is fine as long as you get the recommended tire, such as the continentals or generals.
20x9 rim with the correct offset and you'll be fine
I haven't ruled out going with a 17" inch rim setup either...just trying to figure out what my options are at this point if I were to make a change. A decent road ride is important to me because most of my driving is on the road.
My 2011 limited has 275/55R20 Nitto Terra Grappler on 7" stock rims, work just fine.
Well, upgrading the rims to 9" black ones is in my plan though.
Thanks,
CG
Jhunt
