Originally Posted by TheDurk
You do realize that the letters ND probably stand for "Nippon Denso'? I don't think the sensors Denso sends to Toyota have the after-market part numbers on them. That doesn't mean Denso didn't make them. My factory Aisin water pump has only the Toyota part number on it, too.
If you look at the Denso page for your truck, you will see that DENSO thinks they are the OE manufacturer for those sensors.
DENSO Aftermarket Online Catalog Search | Vehicle Parts Search
LIMITED, SR5
Engine: V6 (3.4L)
VIN: N
Yes, I realize that ND probably does stand for Nippon Denso. However on the "ND" on mine, the last vertical line of the N is shared with the vertical line of the "D". So it's not even really an ND. And I agree, that definitely doesn't mean that Denso didn't made them - like I said,
Apparently the factory O2s aren't Denso. Either that or Toyota put their name on them but had Denso make them.?
But if Denso did make them, they definitely didn't put
their part #s on them like you said - they used Toyota part #s instead as runrunner's and mine show. I don't know who made them for sure, but I have yet to see an original O2 sensor out of a 3rd gen that says "Denso" on it like any of the ones you buy aftermarket. It raises the question, but they did use Denso for most everything else sensor related so it makes the most sense.
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
