Originally Posted by Mr. Leary
I assume that the page you referenced is from the service manual, Singtoe?
Is it an actual relay or is it an internalized logic chip? All I see is a large wire bus coming out of the computer. (If its a booger to find out, don't bother spending too much time on this... I'm just trying to avoid chasing wires cuz its kinda a PITA when you are color blind).
I'm thinking this project might fit in nicely with my computer relocation.
Yes right from the FSM.
The relay is in the passenger side kick panel. No computerized logic chips. It looks just as the diagram. The Newer 4runners (01 and 02) don't use vacuum servos, the use electric actuator. They are hook up to a 4x4 ECU. So they will have the logic chip. Still easy to bypass. Just put a on/off switch at the actuator to prevent it from actuating- locking the A.D.D..
1999 Limited 4runner in
Silver -
9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap -
AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers &
adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax -
Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes -
V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in
Silver On 37's and
Guns for sale
