Thread: 215 85 16?
View Single Post
Old 10-06-2011, 11:51 AM
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Mounting those skinny tires on wide rims will let the tires wear uneven at the wrong PSI. You will have to test to find the right PSI.
Easy test is to spray the tire down with water, drive 20 feet on dry concrete and look at your tire marks. If the edges are not leaving marks, then it is over inflated, if the center is light on the marks, the it is under inflated.
10 ply tires will require 65+ psi any way to keep them from cupping.
BTW, Those tires will be awesome in the deep snow. It should be a mountain goat.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
