Install Continued
STEP BY STEP (cont).- Remove the original wiring harness. I had to bend the metal clip in the harness a bit to get it to slide off the mount.
- Modify the harness removing the three pin solar sensor connector and splicing in your two pin connector. (I tried removing the individual pins for a while but I just couldn’t hit the release.)
- Remove the blank, install the light sensor (it's tight but my big hands managed it without a problem) and connect up the new harness.
- Reassemble everything.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
