View Single Post
Old 12-11-2011, 07:32 AM
Asmara Asmara is offline
Asmara is on a distinguished road
STEP BY STEP (Cont.)
  • [this last bit takes about 10 minutes total. Wow is it easy]
  • Take off the plastic surrounding the steering wheel column. There are three screws. One on the bottom and two others behind the steering wheel that you can only see if you rotate the steering wheel 90 degrees each way.
  • Unscrew the Headlight dimmer (headlight stalk) and swap in the new one.
  • Reassemble and you now have automatic headlights.
OEM Automatic Headlight Install-sm-cover-screw-jpg  OEM Automatic Headlight Install-sm-stalk-screws-jpg  OEM Automatic Headlight Install-sm-installed-jpg
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
Asmara is offline   Reply With QuoteReply With Quote
