Two of the main problems CBs have issues.
Bad grounds. Radio and antennas. Even though the radio is grounded, in theory, thru the ground power wire, I run another ground wire from the CB chassis to the truck body. Also make sure there is a good, non-painted/non-corroded mounting point for the antenna.
The other problem is that the extra antenna cable CAN NOT be coiled up. It acts like a choke and your radio will not work. If you have extra cable, stretch it out. And NEVER try to transmit without an antenna, you will burn up your radio.
(first post updated)
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
