MAF and too lean?
Well, you need to narrow it down. If you're lean it's because you've got too much air or not enough fuel, now you need to figure out why before you can evaluate your odds of fixing it.
Off the top of my head, a simple test would be to borrow a fuel pressure tester from a chain store and make sure your pump is working properly. You can also have a good hard look at your intake boot between the throttle body and the MAF and make sure there's no leaks or tears there allowing unmetered air in. I'm not a mechanic either though, so I'm sure more experienced folks will chime in with more suggestions.
I think it's great that you're willing to get in there and get your baby running right.
