1995 4 runner lift kit ome
trd_no.1
so after alout of thought look like im going to go with the 2" ome lift kit with the torsion bars. my one question about it is if i crank the torsion bars wont my tires be stuck on a angle pointing out . i know a wheel aligment could help after but i was just wondering ive herd people say that it wont work and the wheels will not sit right is this ture ?
If the OME lift is properly installed and the front aligned afterwards, you won't have a problem. If you go adjusting the t-bars for more height, you can run into problems.
The OME kits are quality stuff, the ride and handling is better than new.
If you get the kit from Toytec it comes with 2" ball joint spacers and you won't need to crank the torsion bars. If anything, you could relax them for a better ride.
Are those really 2 inch ball joint spacers? I have yet to see a "2 inch ball joint spacer" that wasn't actually a 1.5 inch spacer with instructions to crank the torsion bars to make up the missing half inch.
