Old 03-29-2013, 11:56 AM #1
2Dragons 2Dragons is offline
2Dragons is an unknown quantity at this point
Orange stuff in the radiator
Okay, so I have this 4Runner 1995, v6. I have replaced the water pump, radiator, engine gasket, and I still have those orange stuff (like slush if I leave it too long and not changing the antifreeze often) in the radiator. If this keeps going on, the engine gets very hot and the gasket gets burn again. I need to troubleshoot where these orange/yellow stuff is coming from and what causes it to occur. I know for a fact that it's not rusts. The radiator was replaced less than two years. Any suggestion is much appreciated.
2Dragons is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 12:02 PM #2
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I don't know what that would be besides rust, there's not much else that orange sludgy stuff could be. Give your entire cooling system (not just the radiator) a good flush and cleaning, and then use nothing but Toyota red coolant.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 12:11 PM #3
I did try to flush and clean it up before putting new coolant in. It's been less than 4 months and it's already yellow/orange again. I don't think the brand new radiator would rust that easily. It's only been two years at most.
Old 03-29-2013, 12:21 PM #4
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Your engine block may be rusting inside the cooling jacket and if that's happening then you will always get rust because the only way to clean that is a acid dip.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 01:43 PM #5
nicnmike's Avatar
nicnmike nicnmike is offline
nicnmike is on a distinguished road
nicnmike's Avatar
I found this write up the other day. Scroll down to the part about anti-freeze. The whole thread is pretty good too.
edit, the link:
http://www.yotatech.com/f116/what-ev...k-3vze-187741/
nicnmike is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 02:46 PM #6
ed4stoy88's Avatar
ed4stoy88 ed4stoy88 is offline
ed4stoy88 is an unknown quantity at this point
ed4stoy88's Avatar
A bad radiator cap can cause this ,air getting in your system.
ed4stoy88 is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 04:32 PM #7
edit, the link:
What EVERYONE should know about their truck & the 3VZE - YotaTech Forums
Many thanks for the tips. I'll give those writeup some reading tonight.
Old 03-29-2013, 07:26 PM #8
Okay, here's what it looks like.
Old 03-29-2013, 07:39 PM #9
Real Name: Kevin
Real Name: Kevin
$10 says that's rust.
Old 03-29-2013, 07:47 PM #10
Bad_Vision's Avatar
Bad_Vision's Avatar
That's solid rust man I think it's time to acid wash and replace the bypass tube and the lower coolant hose tube to be safe.
Old 03-29-2013, 09:09 PM #11
nicnmike's Avatar
nicnmike's Avatar
I believe there are flush kits out there that allow you to hook up a hose to your system. Maybe you could try taking out the thermostat, use the hose to do a constant flush and drain out of one of the drains on the block. This is with the engine off, of course.
Old 03-29-2013, 09:53 PM #12
TX_QtPi TX_QtPi is offline
Real Name: Cynthia
TX_QtPi is on a distinguished road
Real Name: Cynthia
Agreed. rust. Acid wash and replace the water pump n 2 hoses just for good measure if it's that bad.
Cynthia
TX_QtPi is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 10:55 PM #13
The main question is, where are these "rusts" coming from then? Even if I replaced a new radiator or water pump, it will get like this in about 3 - 6 months. I need to find the source and fix that instead of the symptoms.
Old 03-31-2013, 10:18 AM #14
Bad_Vision's Avatar
Bad_Vision's Avatar
once again ill say it as i stated above!!! the rust is probably coming from the block itself and the only way to fix it is a acid dip.
youll need to replace all your hoses and you water pump and for good measure replace the heater core and the bypass tubes.
Old 04-06-2013, 10:44 AM #15
AzDirtRunner's Avatar
AzDirtRunner AzDirtRunner is offline
AzDirtRunner is on a distinguished road
Check your reservoir/overflow tank. I had the same issue,I flushed it like 3 times and nothing changed. I finally removed the reservoir tank and it had almost 2 inches off crud in the bottom. Cleaned it out and did one more good long flush, my coolant looked way better after that.
95 4runner 3.0, stock, two 12" subs, and a train horn, more to come tho
AzDirtRunner is offline   Reply With QuoteReply With Quote
Orange Liquid in Air Box jeff elzy Classic T4Rs 9 06-26-2012 04:15 PM
Orange Peel anyone? adio3x 5th gen T4Rs 4 07-02-2010 01:54 PM
Will this KOYO radiator work as an OEM radiator as far Gavin S. 3rd gen T4Rs 9 06-08-2010 11:04 PM
Orange on my rotors trijicon 4th Gen T4Rs 6 04-14-2006 07:35 AM
Toyota of Orange zduchene Dealers - Your Experience 1 10-17-2005 03:37 AM
