sensor question....
ralatkins
I need some help with identifying a sensor on my 3.0. I had to change my alternator the other day and there is a sensor right beside the lower alternator bracket. a previous owner had damaged the wire running to the plug on this sensor and had the wire taped on. I want to replace the plug and sensor but I do not know what sensor it is. if anyone has a clue..............
btw, if you didn't notice I am a little mechanically challenged.
The best wayto identify sensors is to pull it off and type the part number in to google. You'll have an answer right away.
