wheel ???
Most any Japanese make of wheels will fit if they are 6 hole. Chevy wheels fit too, but check for the hub clearance: some Chevy wheels will not fit over the hub (center hole).
Offset is a big thing to watch for too. Too much and your wheels will stick out of the fenders (not good for street driving and illegal in a lot of places), too little or negative offset and you may not clear your brakes.
HMMM????
I was just curious, because I wanted another set of rims to mount mudders or studded tires on, and it is usualy cheaper to buy used factory rims, than aftermarket rims.
Re: HMMM????
You can usually find the steel 7-spoke pretty cheap. Check eBay or AAA rims.
Mike iin AR
Re: hmm
doc76239 said:
Does any one know the back spacing and pattern size foe the stop rims?
Backspacing on stock ALUMINUM wheels is 4.25 inches. I just measured them, since they are now off the 4Ruuner.
I just switched and put my stock 7-spoke steel wheels back on , yesterday. They have my summer tires mounted on them. However, I didn't measure the backspacing while I had them off.
Mike in AR
