Hi All,
Greetings from Australia. I've just bought a 93 4Runner. My first 4WD. It's done about 105,000 Km (63K miles). Apparently the lady who owned it, drove it to the supermarket and back with not a lot of off roading.
I've had the car inspected by Toyota. I've spent about $1400 on changing the Timing Belt, Drive Belts and the Water pump (apparently had a leak)
Toyota have ironed out most of the issues except a faint grinding noise in the 4th gear (3.0L V6 Manual). Before I had it serviced by Toyota the noise was a lot worse. Toyota now tell me that they can't do much about it.
Has anyone of you had a similar problem ? Any pointers, tips and suggestions is gladly appreciated.
Thanks a ton,
Sri
Thanks a ton,
Sri
