Tire clearance on '92 4Runner
nogard
I have a '92 4Runner with 31x11x15. The rims have a little more positive offset than the stocks, so I think this adds to the problem. The truck is also at stock ride height. When the tires are turned to full lock, the back of the tire just rubs the rear of the wheel well. And this is on level ground! What can I do? I would like to put on a set of cut out flares, but they don't make them for this model. I think mainly because it would be hard to cut out the rear wells because the rear door is part of it. Any ideas, I would really like to cut out the wells, but not sure how to with the doors? I know a lift would help, but I don't want to make it any taller that I have to.
Thanks.
You could remove the lining/shield thing and hammer down the seam... There's an article floating around on it. Also, you could crank the t-bars a bit or step up to SAW t-bars. Or, you could get different rims and tires...
