OME Front Lift 885/N140S Fully Assembled
Vegas Runner
OME Front Lift: $375.00
885 OME Coil Springs
N140S OME Struts
Fully Assembled with Toyota Top Plate
$375 is about 60% of what I paid for the fully assembled front Suspension
The advantage of having the suspension fully assembled with the springs already compressed and assembled with the Toyota top plate is you can just pull out your stock suspension and replace it with these. You do not have to dis-assemble your stock suspension and assemble the OME suspension using the top plate from your stock suspension. Compressing the springs can be tough to do yourself and a shop will charge you about $75.00. When I bought these originally from Slee I had them assemble them for me.
For more information on how to install these check out the write up that I did when I originally purchased them:
OME Lift Installation Write Up
Shipping will be actual UPS charges 45 pounds from zip code 89052.
I am selling these because I removed them and installed Donahoe Coilovers.
-Ed
