Tow kits: Bolt-on vs. Welded??
Would you trust a "bolt-on" style towing hitch?
  • Heck yeah! Bolt one on!
    Votes: 0 0.0%
  • No way! Get a real one welded on!
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Mojoski
I am about to get a '96 4Runner and need to add a tow kits for small trailers. Do I need to get a kit put on my a professional that will weld it and such, or can I feel comfortable buying one of those Class III bolt on ones like this?
Bolt-on Hitch
One of my buddies told me he "wouldn't trust a bolt-on tow kit", but obviously plenty of people do. What do you guys think? All I plan on towing, at least that I know of at this time, is a small trailer with a bunch of camping gear in it, and maybe one day a small trailer with a couple of 4-wheelers on it. Would a bolt-on trailer hitch like this one be sufficient for that type of work?
Thanks for all input!
Mojoski
OEM is fine for towing the 4Runner's limit and I've yet to read of naybody having an issue with one.
I went with a Curt WD model for my recently purchased 2008 T4R V6.
Extremely satified with a bolt-on, just make sure you torque the bolts to manufacturer spec. Should only take an hour at best to install yourself.
A bolt on tow hitch can be stronger than a weld on, depending on the design of each. Usually with bolt on hitches, the bolts will pass completely through the frame which gives them a double shear break point. Couple this with an internal sleeve (through the frame) and you've got a hitch that is much stronger than one that is simply welded to the outside of the frame.
