HELP light install
Mason Fresh
1 2 SUPER BLUE INVERTED CONE LED 194 158 168 $1.99 (license plate)
2 SUPER BLUE INVERTED CONE LED 194 158 168 - license plate
1 2 HID WHITE INVERTED CONE WEDGE BASE LED 194 158 168 $1.99
2 HID WHITE INVERTED CONE WEDGE BASE LED 194 158 168 - license plate also, im gonna try both to see which i like
1 V-LEDS 5K WHITE 1W HP LED DOME LIGHT BULB 3022 3021 DE3175 $6.99
V-LEDS 5K WHITE 1W HP LED DOME LIGHT BULB 3022 3021 DE3175 - dome light
1 HIGH POWER SMT 3 LED BLUE VANITY LIGHT BULB $4.99
HIGH POWER SMT 3 LED BLUE VANITY LIGHT BULB - vanitys
will all this work? did i order the right things? =/ i did a fitment check guide but for some reason i'm a little nervous, thanks for anyone who helps...
also, I'm sure most of you know about this, but for those 4runner enthusiasts there is a coupon code you can use up to five times on v-led.com - gets you 15percent off your whole order. type in 4RUNNER as the coupon code.
:reddance:
The 194 wedge bulbs are correct. Your courtesy door lights, map lights and running board lights (if you got them) uses these bulbs.
I'm not sure about the dome as my Camry and 4Runner the length of bulbs are different between the two, yet the housing is identical.
I didn't swap my vanity lights. Did you check J.A.'s site?
